Home > Technical > Rear wiper judder
Andyslandytd5
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Rear wiper judder
I have a minor rear wiper issue I need to sort and as I am taking the rear wheel off the door soon (changing alloys) I figure it would be a good time to look into it.
My rear wiper judders across the screen when returning to the hold postion. I have put a new blade on and its no different. The only time it does not do it is if its extremely wet.
This is my 4th defender so I no its not normal, any thoughts? 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
2004 TD5 90 XS Station Wagon - 2019-2024
2003 TD5 90 G4 LE - 2009-2010
1990 Ninety 6.2 V8 Station Wagon - 2006-2009
Post #1075011 8th Sep 2025 11:00am
Martin
Site Admin
Question split to its own thread  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1075013 8th Sep 2025 11:08am
Andyslandytd5
Thanks Martin, apologies should have done that from the start. 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
Post #1075018 8th Sep 2025 11:33am
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
Hi
Have you coated the rear screen with Rain X or a similar product?
You can try cleaning the glass with detergent and fine grade wire wool. Then finish it off with a wipe over of decent glass cleaner.
Jim
Post #1075022 8th Sep 2025 12:40pm
Andyslandytd5
Good shout I will give that a try. Its a minor irritation that I have been meaning to look at for a while. As I am taking the spare off soon anyway I figured now is the best time to do it 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
Post #1075034 8th Sep 2025 2:11pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Put some twist into the wiper arm. The blade needs to be held at 90 degrees to the glass. Your wiper arm has possibly taken a knock at some point and is no longer at 90° so is pushing the blade across the glass rather than dragging it as it returns to park.
Post #1075063 8th Sep 2025 9:47pm
I Like Old Skool
Forget the fancy snake oil treatments. Not necessary if you just get it set up correctly 👍
Post #1075065 8th Sep 2025 9:51pm
I Like Old Skool
Double post.
Post #1075066 8th Sep 2025 9:51pm
Andyslandytd5
Cheers, I will try that a try, Though if its 90° in one direction would that not make it 110° in the other direction? 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
Post #1075108 9th Sep 2025 1:43pm
excossack
My poor wiper performance, was down to a couple of things
knackered wiper blade, arm not sitting right and probably caused by worn splines on the wiper motor.
Replaced all of them and now much better! 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1075111 9th Sep 2025 2:03pm
Andyslandytd5
Did what you said and works a treat! No more annoying wiper judder on the rear! Thanks mate 😀 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
Post #1076864 4th Oct 2025 1:19pm
