![]() | Home > Technical > Rear wiper judder |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6705 ![]() ![]() ![]() |
Question split to its own thread
Andyslandytd5 Member Since: 06 Nov 2021 Location: Southampton Posts: 80 ![]() ![]() ![]() |
Thanks Martin, apologies should have done that from the start. 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
2004 TD5 90 XS Station Wagon - 2019-2024 2003 TD5 90 G4 LE - 2009-2010 1990 Ninety 6.2 V8 Station Wagon - 2006-2009 |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 988 ![]() ![]() ![]() |
Hi
Have you coated the rear screen with Rain X or a similar product? You can try cleaning the glass with detergent and fine grade wire wool. Then finish it off with a wipe over of decent glass cleaner. Jim |
Good shout I will give that a try. Its a minor irritation that I have been meaning to look at for a while. As I am taking the spare off soon anyway I figured now is the best time to do it 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 868 ![]() ![]() ![]() |
Put some twist into the wiper arm. The blade needs to be held at 90 degrees to the glass. Your wiper arm has possibly taken a knock at some point and is no longer at 90° so is pushing the blade across the glass rather than dragging it as it returns to park.
Forget the fancy snake oil treatments. Not necessary if you just get it set up correctly 👍
Double post.
Cheers, I will try that a try, Though if its 90° in one direction would that not make it 110° in the other direction? 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present 2004 TD5 90 XS Station Wagon - 2019-2024 2003 TD5 90 G4 LE - 2009-2010 1990 Ninety 6.2 V8 Station Wagon - 2006-2009 |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6026 ![]() ![]() ![]() |
My poor wiper performance, was down to a couple of things
knackered wiper blade, arm not sitting right and probably caused by worn splines on the wiper motor. Replaced all of them and now much better! 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
