![]() | Home > Technical > Hi low gear change |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2529 ![]() ![]() |
Are you saying the connecting rod, with the black plastic connector on the end that attaches to the transfer box is missing, or the black plastic bit is missing, or the black plastic bit has detached from the LT230. Noting with the latter it can be reattached to the LT230 by depressing the lock button and pushing it back on.
If the rod or rod plastic end is missing unfortunately it’s not available separately, it’s part 3 in this picture and is the whole lever and linkage as one https://parts.jaguarlandroverclassic.com/p...and-rover/ Part number LR018374 - Linkage Cheaper to buy used part from breakers or on eBay. |
Jack1c Member Since: 31 Aug 2025 Location: Cumbria Posts: 3 ![]() ![]() |
No it's the ball connection that's missing
Damm, it’s either a breaker or its going to cost a lot to buy the whole lever mechanism !!
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2684 ![]() ![]() ![]() |
sorry for the hijack, is there a way to wire a light to come on when you switch to Low? --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 691 ![]() ![]() ![]() |
TD5 transfer boxes has switch for this. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
Thanks for all the help gents but sorted now used ball end of a gas strut thread lock and nut works better then factory
