Home > Technical > Hi low gear change
Jack1c
Hi low gear change
Hi new to site can anyone out there help please the high low connection rod to the box is supposed to have a lever with a ball joint on the end were plastic connection goes, as come out so can't select hi or low we're do you find a new part looked all over the Internet and no luck puma 2.4 2010
Post #1074442 31st Aug 2025 6:02pm
Ianh
Are you saying the connecting rod, with the black plastic connector on the end that attaches to the transfer box is missing, or the black plastic bit is missing, or the black plastic bit has detached from the LT230. Noting with the latter it can be reattached to the LT230 by depressing the lock button and pushing it back on.
If the rod or rod plastic end is missing unfortunately it’s not available separately, it’s part 3 in this picture and is the whole lever and linkage as one https://parts.jaguarlandroverclassic.com/p...and-rover/
Part number LR018374 - Linkage
Cheaper to buy used part from breakers or on eBay.
Post #1074457 31st Aug 2025 7:32pm
Jack1c
No it's the ball connection that's missing
Post #1074602 2nd Sep 2025 6:55pm
Ianh
Damm, it’s either a breaker or its going to cost a lot to buy the whole lever mechanism !!
Post #1074624 3rd Sep 2025 1:08am
Naks
sorry for the hijack, is there a way to wire a light to come on when you switch to Low? --
Post #1074629 3rd Sep 2025 8:32am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
TD5 transfer boxes has switch for this. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1074630 3rd Sep 2025 8:38am
Jack1c
Thanks for all the help gents but sorted now used ball end of a gas strut thread lock and nut works better then factory
Post #1074678 3rd Sep 2025 7:32pm
