Home > Puma (Tdci) > Black smoke
Page 1 of 4 1234>
Topvaruk
Slovakia 2008 Defender 110 Puma 2.4 CSW Alaska White
Black smoke
Evening all!
New problem today.
My 2008 110 has got very smoky. Little down on power I think. No smoke when accelerating hard, but lots when holding a speed.
It’s the black smoke associated with overfilling/air problems
Has new hoses
New MAP
New MAF - but thought I would just check.
This is only 3 months old - about 5000km since changing.
Previous owner says the car has an EGR blanking plate fitted - from what he says I think it’s at the cooler/exhaust connection
Exhaust tip is very sooty
If the EGR is blanked what could cause the MAP to get so sooty so quickly?
I think I can hear a putt putt putt noise from the air intake on the wing.
Have cleaned up eve thing and will take for a run tomorrow.
I have spent 3 hours searching here - but can’t find anything definitive
Any pointers greatly appreciated 2010 90 LHD soft top
2010 110 XS
2008 110 E LHD
1985 90 soft top
Post #1074398 30th Aug 2025 9:31pm
BrickBox
Sounds like a split intercooler hose
(Black smoke and down on power) 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS.
Post #1074399 30th Aug 2025 9:37pm
Ianh
Have you a diagnostic tool to check for any Diagnostic Trouble Codes ( DTC’s) ?
Post #1074400 30th Aug 2025 9:46pm
Topvaruk
Thanks for the replies
New silicon hoses all round
No error codes on my BB evo
Might change the VCV next - have one in the shed
Will go to the local dealer next week and get them to pressure test the air side - might be a blocked or leaking intercooler 2010 90 LHD soft top
2010 110 XS
2008 110 E LHD
1985 90 soft top
Post #1074403 30th Aug 2025 10:33pm
Ianh
Perhaps warn injector seals causing pressure in the crankcase that vents via the breather pipe into the turbo inlet hose, then onwards to the map sensor and gunking it up. That could explain the intake noise as well.
Post #1074404 30th Aug 2025 10:55pm
Topvaruk
Bingo
I was thinking the same
Might account for the putt putt noise also 2010 90 LHD soft top
2010 110 XS
2008 110 E LHD
1985 90 soft top
Post #1074408 31st Aug 2025 6:33am
Topvaruk
So cleaning the MAP sensor worked - no smoke now
Just the WHY to solve
Have ordered an injector seal kit along with rocker cover gaskets, stretch bolts etc
Also ordered the seal seating tool to make sure its all good - couldn't find the exact size of the injectors so got the universal kit
Seen a few how to guides on the tube - looks easy enough
Oil change once done
I am guessing my intake system from the point the breather connects will be full of soot also.
Are the aerosol spray cleaners any good?
I wont start the conversation about squirting water mist/coca cola/snake oil into the intake. 2010 90 LHD soft top
2010 110 XS
2008 110 E LHD
1985 90 soft top
Post #1074413 31st Aug 2025 10:51am
Are you sure the air filter isn’t dirty?
While your there, put a few drops of lube on the Turbo actuator pivots and check the vanes are free. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1074414 31st Aug 2025 10:53am
BrickBox
Just take your time taking the plastic return pipes off the injectors, they can be brittle if they’re original. And don’t drop/lose the green retaining clips for them. 2017 5.0 V8 Supercharged RRS SVR
Post #1074415 31st Aug 2025 11:03am
Consider also fitting a catch can to the breather.
Post #1074416 31st Aug 2025 11:10am
Topvaruk
Thanks all
New air filter
Good catch on the clips - I’ll remember this
Catcher - not a bad idea. Is it a fleabay item? 2010 90 LHD soft top
2010 110 XS
2008 110 E LHD
1985 90 soft top
Post #1074423 31st Aug 2025 12:20pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
+1 on fitting a catch-can/oil-separator in the breather line.
I have removed the EGR and replaced injector seals. Virtually no blow by if I open the oil filler. Still my oil separator picks up a little oil between oil changes, say under 100cc every 5K. Not much, true, but I'd rather it didn't get into my intake system. Makes me wonder why the intercooler doesn't have a drain.
Post #1074428 31st Aug 2025 2:26pm
Ianh
On the injector removing, be very very careful that the little plug from the toolkit that fits in the hole at the bottom to stop detritus getting into the cylinder while cleaning is a good fit. Some topics on here have been on the nightmare scenario of that plug dropping into the cylinder !!!!!
On the catch can. A genuine provent is the way to go, not cheap Chinese or fake and there are a lot of fakes out there. Most use a provent 200 but some a 100. Lots of topics on here including fitting location and hose adapters.
Post #1074438 31st Aug 2025 4:26pm
BrickBox
I believe a 100 is enough for a Defender. 2017 5.0 V8 Supercharged RRS SVR
Post #1074446 31st Aug 2025 6:15pm
TriniDaddy
2008 Defender 110 Puma 2.4 XS CSW Arles Blue
Started getting the same thing the other day.
Just after a healthy Italian tune up. Started hearing a bit of a hiss on acceleration, thought I was hearing the turbo but doesn't seem to be the case. Then the smoke started. Now there's a loss of power on acceleration revs up to 25/28000rpm then just stays there, no matter how much I press the pedal (could be potentiometer, still have to verify). No engine lights, no error codes.
But I took a snoop on Saturday and saw some sort of oily residue on the end of the hose from the EGR it looks like. Cleaned it off and surrounding hoses. Had a long drive on Saturday, been parked since yesterday morning, about to check and see if I can tell for sure where the leak is, will take some pics. Would prefer changing the hoses more than the pedal. Just to know for sure... 110 SW 2.4
IZUMI BLUE
Post #1074527 1st Sep 2025 8:57pm
Page 1 of 4 1234>
