![]() | Home > Puma (Tdci) > Black smoke |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1105 ![]() ![]() ![]() |
Sounds like a split intercooler hose
(Black smoke and down on power) 2017 5.0 V8 Supercharged RRS SVR 2008 2.4 110 Utility Station Wagon XS. |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2526 ![]() ![]() |
Have you a diagnostic tool to check for any Diagnostic Trouble Codes ( DTC’s) ?
Topvaruk Member Since: 25 Apr 2018 Location: bratislava Posts: 97 ![]() ![]() ![]() |
Thanks for the replies
New silicon hoses all round No error codes on my BB evo Might change the VCV next - have one in the shed Will go to the local dealer next week and get them to pressure test the air side - might be a blocked or leaking intercooler 2010 90 LHD soft top 2010 110 XS 2008 110 E LHD 1985 90 soft top |
Perhaps warn injector seals causing pressure in the crankcase that vents via the breather pipe into the turbo inlet hose, then onwards to the map sensor and gunking it up. That could explain the intake noise as well.
Bingo
I was thinking the same Might account for the putt putt noise also 2010 90 LHD soft top 2010 110 XS 2008 110 E LHD 1985 90 soft top |
So cleaning the MAP sensor worked - no smoke now
Just the WHY to solve Have ordered an injector seal kit along with rocker cover gaskets, stretch bolts etc Also ordered the seal seating tool to make sure its all good - couldn't find the exact size of the injectors so got the universal kit Seen a few how to guides on the tube - looks easy enough Oil change once done I am guessing my intake system from the point the breather connects will be full of soot also. Are the aerosol spray cleaners any good? I wont start the conversation about squirting water mist/coca cola/snake oil into the intake. 2010 90 LHD soft top 2010 110 XS 2008 110 E LHD 1985 90 soft top |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21012 ![]() ![]() |
Are you sure the air filter isn’t dirty?
While your there, put a few drops of lube on the Turbo actuator pivots and check the vanes are free. ![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ Last edited by custom90 on 1st Sep 2025 9:25pm. Edited 1 time in total |
Just take your time taking the plastic return pipes off the injectors, they can be brittle if they’re original. And don’t drop/lose the green retaining clips for them. 2017 5.0 V8 Supercharged RRS SVR
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18016 ![]() ![]() ![]() |
Consider also fitting a catch can to the breather.
Thanks all
New air filter Good catch on the clips - I’ll remember this Catcher - not a bad idea. Is it a fleabay item? 2010 90 LHD soft top 2010 110 XS 2008 110 E LHD 1985 90 soft top |
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 278 ![]() ![]() ![]() |
+1 on fitting a catch-can/oil-separator in the breather line.
I have removed the EGR and replaced injector seals. Virtually no blow by if I open the oil filler. Still my oil separator picks up a little oil between oil changes, say under 100cc every 5K. Not much, true, but I'd rather it didn't get into my intake system. Makes me wonder why the intercooler doesn't have a drain. |
On the injector removing, be very very careful that the little plug from the toolkit that fits in the hole at the bottom to stop detritus getting into the cylinder while cleaning is a good fit. Some topics on here have been on the nightmare scenario of that plug dropping into the cylinder !!!!!
On the catch can. A genuine provent is the way to go, not cheap Chinese or fake and there are a lot of fakes out there. Most use a provent 200 but some a 100. Lots of topics on here including fitting location and hose adapters. |
I believe a 100 is enough for a Defender. 2017 5.0 V8 Supercharged RRS SVR
TriniDaddy Member Since: 23 Nov 2020 Location: 10.57422, -61.28906 Posts: 50 ![]() ![]() |
Started getting the same thing the other day.
Just after a healthy Italian tune up. Started hearing a bit of a hiss on acceleration, thought I was hearing the turbo but doesn't seem to be the case. Then the smoke started. Now there's a loss of power on acceleration revs up to 25/28000rpm then just stays there, no matter how much I press the pedal (could be potentiometer, still have to verify). No engine lights, no error codes. But I took a snoop on Saturday and saw some sort of oily residue on the end of the hose from the EGR it looks like. Cleaned it off and surrounding hoses. Had a long drive on Saturday, been parked since yesterday morning, about to check and see if I can tell for sure where the leak is, will take some pics. Would prefer changing the hoses more than the pedal. Just to know for sure... 110 SW 2.4 IZUMI BLUE |
