Home > Puma (Tdci) > Black smoke
Page 4 of 4 <1234
MK
It's normal. Try to record the putt putt noise. Puma 110" SW
Post #1075809 20th Sep 2025 6:52pm
Topvaruk
Slovakia 2008 Defender 110 Puma 2.4 CSW Alaska White
Ok thanks
I’ll record it (try) and upload.
Just for clarity - i am get positive pressure from the small airbox connection that the crank case hose pushes on to
See image …. Red arrow is where positive air pressure is coming from with the PCV hose off
 2010 90 LHD soft top
2010 110 XS
2008 110 E LHD
1985 90 soft top
Post #1075832 21st Sep 2025 7:50am
Topvaruk
One slight update
Went to a diesel specialist today
His opinion is that denso injectors cant really be refurbished. Just tested and calibrated - he will do this later today.
Also the slight positive pressure on the airbox connector - well this is still true at idle but when i rev, it reverses and starts drawing in.
Anyone with a 2.4 would you mind verifying this is correct by pulling of the PCV hose and seeing if you can feel positive air coming from the airbox side? I would really appreciate it.
I still smell a rat with the cheap turbo. 2010 90 LHD soft top
2010 110 XS
2008 110 E LHD
1985 90 soft top
Post #1075901 22nd Sep 2025 12:28pm
Page 4 of 4 <1234
