![]() | Home > Puma (Tdci) > Black smoke |
Topvaruk Member Since: 25 Apr 2018 Location: bratislava Posts: 97 ![]() ![]() ![]() |
![]() Click image to enlarge Ok thanks I’ll record it (try) and upload. Just for clarity - i am get positive pressure from the small airbox connection that the crank case hose pushes on to See image …. Red arrow is where positive air pressure is coming from with the PCV hose off ![]() Click image to enlarge 2010 90 LHD soft top 2010 110 XS 2008 110 E LHD 1985 90 soft top |
One slight update
Went to a diesel specialist today His opinion is that denso injectors cant really be refurbished. Just tested and calibrated - he will do this later today. Also the slight positive pressure on the airbox connector - well this is still true at idle but when i rev, it reverses and starts drawing in. Anyone with a 2.4 would you mind verifying this is correct by pulling of the PCV hose and seeing if you can feel positive air coming from the airbox side? I would really appreciate it. I still smell a rat with the cheap turbo. 2010 90 LHD soft top 2010 110 XS 2008 110 E LHD 1985 90 soft top |
Swapped out the ‘refurbished’ injectors for new. Coded up first time. Also pilot learn without any drama. Induction noise still there. Checking the transit forum seems common, just resonance of the airbox. Going to swap the turbo next week for a genuine one to see if it makes any difference After that - a louder radio and live with it 2010 90 LHD soft top 2010 110 XS 2008 110 E LHD 1985 90 soft top |
