Home > Puma (Tdci) > Intermittent 2.2 engine power loss
Sybrow
United Kingdom 2012 Defender 110 Puma 2.2 DCPU Keswick Green
Hi. Would appreciate any advice as I am getting intermittent power loss. I've a 2012 110 2.2. It's done 65k miles and it has had a BAS stage 2 remap and an Alive intercooler.
I get periodic loss of power, which lasts for anywhere from 5 to 20 seconds. I think it happens when I over rev the engine as I have noticed it a couple of times when going up hills (on the road). I'm starting to lose confidence in the engine, so would appreciate any thoughts on what it might be?
When I say power loss, I can just about maintain the current speed, but cannot accelerate.
I've tried using my (cheapish) ODB reader both when stationary and also whilst driving (so I could run a scan when I get power loss), but have not had any fault codes register either time.
Post #1073600 18th Aug 2025 4:27pm
Johan_B
Sweden 2007 Defender 110 Puma 2.4 CSW Tonga Green
I had engine protection kick in a few times last summer due to high cylinder head temperature. I could be wrong but it felt as if there were two steps, first a gentle power restriction and then more severe.
Is it related to high ambient temperature?
Check coolant and condition of radiator.
Try to read CHT to see if it runs unusually warm.
Post #1073602 18th Aug 2025 5:10pm
Sybrow
Thumbs Up
Post #1073604 18th Aug 2025 5:23pm
andy63
I think you are on the right lines , trying to monitor the main pids, but maybe easier done if you use an app like torque and have the phone up on the dash with say maf, rail pressure and manifold boost on the same page..see if anyone of the readings look abnormal or change dramatically when you notice the loss....
Post #1073692 19th Aug 2025 2:37pm
Sybrow
OK, looks like you were right. It happened again and this time I noticed the engine temp had shot up into the red and I lost power, after a few seconds it shot back down to the middle again and power was restored. As I'm pretty sure the engine cannot gain that much heat and lose it again in a matter of a few seconds, does this look like a faulty engine temperature sensor?
Post #1073719 19th Aug 2025 8:06pm
Johan_B
Exactly how mine behaved. Don’t be fooled by the gauge behaviour. The needle will sit at nominal until a threshold is reached and then rise rapidly. It doesn’t show the actual temperature in a linear way. Once power is reduced it will drop just as fast.
I changed coolant and radiator and now no problem. Old radiator was blocked by mud and dirt to 25%, could’ve cleaned it but since it was 18 years old I just replaced it.
Post #1073722 19th Aug 2025 9:09pm
Sybrow
Thanks JohanB
Post #1073723 19th Aug 2025 9:12pm
Ianh
Note: The 2.4 ECU uses a cylinder head temperature sensor to calculate the coolant temperature whereas the 2.2 has a separate dedicated sensor to directly measure coolant temperature and feed that to the ECU.
Have you checked for loss of coolant ?
NB. I hope it’s not the case, however a head gasket or head issue can cause similar symptoms, as could a leaking EGR cooler ( an issue with 2.2’s). So if temp sensor and radiator are found to be ok then a Reld test would be the next thing to do.
Post #1073726 19th Aug 2025 10:07pm
Sybrow
Thanks IanH. Coolant was very low (virtually none in the header tank), so I topped it up.
Post #1073736 20th Aug 2025 5:03am
Ianh
The radiator can spring a small leak on the lower nearside just above the hoses. A tell tale green stain on the radiator will show if it is leaking. Note Nissens make a very good and low price radiator which is at least as good , if not better, than the original.
Post #1073762 20th Aug 2025 10:54am
Sybrow
The filled coolant header tank was virtually empty again when I checked this afternoon. I could not see any leaks at the radiator, but could see coolant on the pipes off the back of the water pump
Post #1073801 20th Aug 2025 6:51pm
Leaking water pump, Transit one and or Borg and beck on mine, they aren’t worth spending LR parts prices on.
B&B one around £60 to £80 iirc, LR gen £200+
Rolling with laughter
Approximations here.* ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1073921 22nd Aug 2025 2:36pm
Sybrow
Thanks Custom90
Post #1073922 22nd Aug 2025 2:38pm
Sybrow
I think my coolant leak is from the engine part just above the oil cooler - can anyone advise what part that is?
Have answered my own question - it is the starter motor. So back to think it is the EGR valve or cooler leaking coolant as cannot see any other signs of coolant leak.
Post #1073957 23rd Aug 2025 1:33pm
andy63
Hi.. there are a load of pipes and clips above that area of the engine but I'm would have thought if any heater egr valve or cooler pipes were leaking you would see them..
The water jacket cooling manifold connects to the block under the inlet manifold and has a spur off to the oil cooler..those connections and joints are not so easily seen..so if its above the oil cooler try and look maybe from underneath at that fitting and oil cooler connection..
Post #1073958 23rd Aug 2025 2:30pm
