![]() | Home > Puma (Tdci) > Intermittent 2.2 engine power loss |
Johan_B Member Since: 20 Sep 2024 Location: Gothenburg Posts: 141 ![]() ![]() ![]() |
I had engine protection kick in a few times last summer due to high cylinder head temperature. I could be wrong but it felt as if there were two steps, first a gentle power restriction and then more severe.
Is it related to high ambient temperature? Check coolant and condition of radiator. Try to read CHT to see if it runs unusually warm. |
Sybrow Member Since: 31 Dec 2023 Location: Skipton Posts: 46 ![]() ![]() ![]() |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 823 ![]() ![]() |
I think you are on the right lines , trying to monitor the main pids, but maybe easier done if you use an app like torque and have the phone up on the dash with say maf, rail pressure and manifold boost on the same page..see if anyone of the readings look abnormal or change dramatically when you notice the loss....
OK, looks like you were right. It happened again and this time I noticed the engine temp had shot up into the red and I lost power, after a few seconds it shot back down to the middle again and power was restored. As I'm pretty sure the engine cannot gain that much heat and lose it again in a matter of a few seconds, does this look like a faulty engine temperature sensor?
Exactly how mine behaved. Don’t be fooled by the gauge behaviour. The needle will sit at nominal until a threshold is reached and then rise rapidly. It doesn’t show the actual temperature in a linear way. Once power is reduced it will drop just as fast.
I changed coolant and radiator and now no problem. Old radiator was blocked by mud and dirt to 25%, could’ve cleaned it but since it was 18 years old I just replaced it. |
Thanks JohanB
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2514 ![]() ![]() |
Note: The 2.4 ECU uses a cylinder head temperature sensor to calculate the coolant temperature whereas the 2.2 has a separate dedicated sensor to directly measure coolant temperature and feed that to the ECU.
Have you checked for loss of coolant ? NB. I hope it’s not the case, however a head gasket or head issue can cause similar symptoms, as could a leaking EGR cooler ( an issue with 2.2’s). So if temp sensor and radiator are found to be ok then a Reld test would be the next thing to do. |
Thanks IanH. Coolant was very low (virtually none in the header tank), so I topped it up.
The radiator can spring a small leak on the lower nearside just above the hoses. A tell tale green stain on the radiator will show if it is leaking. Note Nissens make a very good and low price radiator which is at least as good , if not better, than the original.
The filled coolant header tank was virtually empty again when I checked this afternoon. I could not see any leaks at the radiator, but could see coolant on the pipes off the back of the water pump
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
Leaking water pump, Transit one and or Borg and beck on mine, they aren’t worth spending LR parts prices on.
B&B one around £60 to £80 iirc, LR gen £200+ ![]() Approximations here.* ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Thanks Custom90
I think my coolant leak is from the engine part just above the oil cooler - can anyone advise what part that is?
Have answered my own question - it is the starter motor. So back to think it is the EGR valve or cooler leaking coolant as cannot see any other signs of coolant leak. |
Hi.. there are a load of pipes and clips above that area of the engine but I'm would have thought if any heater egr valve or cooler pipes were leaking you would see them..
The water jacket cooling manifold connects to the block under the inlet manifold and has a spur off to the oil cooler..those connections and joints are not so easily seen..so if its above the oil cooler try and look maybe from underneath at that fitting and oil cooler connection.. |
