![]() | Home > Puma (Tdci) > Whooshing sound under load, couldnt find cracked hose |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6043 ![]() ![]() |
Sounds just like intercooler hose, or the intercooler having a split.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21012 ![]() ![]() |
Try cleaning the MAP sensor and check tube vanes and pivots lube, is the air filter clean or is there a lot of debris in there?
Any signs of oil deposits around any hoses such as mentioned above, the manifold or other areas? ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1862 ![]() ![]() ![]() |
Drop the viscous fan off and try it to see if the noise is still there, does make a loud noise when engaged.
HTH Keith |
piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 235 ![]() ![]() ![]() |
As per Andy Landy check for a leak in the in the induction system between the turbo and the inlet manifold as this will make a similar noise to what you have described. If this is the issue but it hasn’t triggered the engine check light or gone into limp mode it is likely the hole is quite small, which can make it difficult to locate.
Check out the lower part of page 1 of this topic https://www.defender2.net/forum/topic82014.html to help look for leaks. |
HTB Member Since: 24 Mar 2013 Location: Surrey Posts: 74 ![]() ![]() ![]() |
My 2.2 tdci started making a strange sound under load associated with the turbo boost an hour into my drive from London to Durness.... turned around and parked it up. Have been waiting for new hoses from Allisport so in the mean time dissasembled the intercooler hoses. All seemed dissapointingly OK until I got to the last hose.
The hose under the turbo seems somehow suboptimal.... hopefully replacing this does the trick. ![]() Click image to enlarge ![]() Click image to enlarge |
ChrisCSL Member Since: 10 Aug 2019 Location: Berks Posts: 188 ![]() ![]() ![]() |
Blimey! Amazing that was holding together enough to drive
