Home > Puma (Tdci) > 2.4 turbo change
Fijilandy
United Kingdom 2007 Defender 110 Puma 2.4 SW Chawton White
2.4 turbo change
Hi all,
I’m in a situation where with my LHD 2008 2.4 Puma Aircon overseas I will have to change my turbo on my driveway over there. Above average mechanical ability but I haven’t done a turbo before. Can anyone who has done this give me a step by step guide to doing this with any tips that may ensure a good fit. I have a new Garrett turbo with all gaskets, bolts and studs in the box.
As well as any guide to this should I change the oil feed pipe ? and lastly does anyone know if it can be achieved without removing the AC compressor on top. Had a look and seems like the turbo when unbolted can just about squeeze past the AC compressor but not sure.
Currently at home in the UK so can grab any parts I need and take them out to the vehicle for the job.
Cheers.
Post #1072451 29th Jul 2025 8:53pm
bear100
Providing the triangular exhaust bolts aren’t seized it’s not too bad a job, I found the trickiest bit aligning oil return gasket and bolts.
I used the nakatanenga gasket and Holts fire gum exhaust paste which worked a treat.
Fit new nuts and bolts too. 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #1072459 29th Jul 2025 11:05pm
hank
No need to remove the AC compressor.
You will find it straight forward as a person of above average mechanical ability
Remove flexible air pipework, remove exhaust studs/nuts from both flanges, remove oil feed and drain. Turbo will come out. If I remember correctly there might be a bracket on the exhaust manifold that needs to come off.
Some of the studs/nuts will be dry/rusty on the exhaust - get the penetrating fluid on them!
Swap the plastic elbow over to the new turbo then refit.
When I fitted my replacement I could not get the oil return fitted to the underside of the turbo in situ. Instead found it easier to disconnect the drain from the block, fit the drain to the turbo and install in one lump.
 > 110 XS Double Cab
Post #1072473 30th Jul 2025 8:44am
Fijilandy
Thanks heaps guys,
Some good tips there already, especially the one about fitting the oil return to the turbo first, I probably wouldn’t have done that and would be swearing away. Will be interesting to see how it goes.
Should I change the oil return pipe AND the oil feed pipe as well for new ones or will this make the job too difficult? Engine was a drop in replacement from the UK a couple of years ago and is pretty fresh as the vehicle is hardly used. The current turbo works but is sticking and throwing it into limp mode after a while.
Post #1072482 30th Jul 2025 11:17am
MK
IIRC I did not have to remove the A/C compressor. Puma 110" SW
Post #1072501 30th Jul 2025 1:11pm
hank
I didn't replace the oil feed or drain for new, just re-used existing. Two years later all fine Thumbs Up > 110 XS Double Cab
Post #1072504 30th Jul 2025 1:27pm
Likeomg
I'll be doing the same soon...
taking a hybrid turbo off and back to standard
Post #1072522 30th Jul 2025 4:11pm
irishhawk11
Austria 2011 Defender 90 Puma 2.4 HT Santorini Black
Video
Post #1072766 4th Aug 2025 1:07pm
pdv
Belgium 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
i did it my self too, see that you can reach the oil return pipe bolt with your ratched extensions from underneath. also i had 2 seized bolts on the triangular exhaust flang wich i left in place, they wouldn't budge.
i just put new gaskets and reused everything else.
took me 3 hours alone i have a LHD but my ventialtion box is gone so i have more space.
Post #1072854 5th Aug 2025 5:45pm
