![]() | Home > Puma (Tdci) > Serpentine Belt Change parts list. |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2526 ![]() ![]() |
https://www.lrworkshop.com/diagrams/land-r...elts_45005
https://parts.jaguarlandroverclassic.com/p...and-rover/ If you do a search you will find some topics on just changing the pully bearings plus the bearing part numbers. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18016 ![]() ![]() ![]() |
At 107k you probably just need the belt, and probably not even that.
Unless you are having problems with pulleys and the tensioner, leave them alone. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21012 ![]() ![]() |
I agree with Blackwolf on that, they are surprisingly easy to change the belt.
They are recommended I believe to be replaced around every 50k, but they are often in good condition, I think it’s age that is more of an issue that comes in rather than miles. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
