Home > Puma (Tdci) > Serpentine Belt Change parts list.
Kevzeboy
United Kingdom 2011 Defender 110 Puma 2.4 USW Indus Silver
Hello there.
I have a 2011, 2.4 110 without air conditioning. It’s on 107k and I was thinking the serpentine belt, tensioner and idlers probably want changing.
I called my local motor factors the other day to ask if there was a kit available to do the job like a timing belt, water pump kit for a car. No, was the answer.
Does anyone have a parts list to do the job, or are there kits on the market. I have seen the tensioner and belt on eBay, but the idlers want doing while in there. Good practice and all that.
Kevin
Post #1072177 25th Jul 2025 11:30am
Ianh
https://www.lrworkshop.com/diagrams/land-r...elts_45005
https://parts.jaguarlandroverclassic.com/p...and-rover/
If you do a search you will find some topics on just changing the pully bearings plus the bearing part numbers.
Post #1072183 25th Jul 2025 1:07pm
At 107k you probably just need the belt, and probably not even that.
Unless you are having problems with pulleys and the tensioner, leave them alone.
Post #1072185 25th Jul 2025 1:17pm
I agree with Blackwolf on that, they are surprisingly easy to change the belt.
They are recommended I believe to be replaced around every 50k, but they are often in good condition, I think it’s age that is more of an issue that comes in rather than miles. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1072208 25th Jul 2025 6:24pm
