![]() | Home > Puma (Tdci) > defender wont start |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8395 ![]() ![]() ![]() |
No starter relay clicking? Cheers
Naycrx Member Since: 11 Oct 2023 Location: Nottinghamshire Posts: 168 ![]() ![]() |
Hi, just disconnected negative... immobiliser all seems OK.... but won't start. I have just connected the old battery that's almost flat ..with jump leads and now just keeps clicking.... maybe dead battery...
Battery reading about 8v - as we have a Gauge in the dash pod
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2501 ![]() ![]() |
That’s way way too low, you have a dead battery that either needs charging or needs replacing if won’t charge.
Do you have another vehicle you can use to jump start your defender, if it jumpstarts and runs with leads still connected then that proves it’s the battery |
I have a big jump back at work - so ill try that when i get home.
Funny thing is when i connected the old battery from our shed, it then started clicking but the Volts only rose slightly- as it was pretty much dead- but it seemed to do more when connected How Many Volts does it need to evan attempt to start? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20964 ![]() ![]() |
![]() Click image to enlarge Sounds like you have parasitic drain, but could be that the battery needs replacing, or Alternator is toast. If you charge the battery, then all is well, find out immediately if it’s parasitic drain or alternator failing to produce charging current voltage. If at rest and you don’t know if there is parasitic drain, or it’s not identified, leave the battery disconnected or you will get a dead battery again. Has any work been done on it recently? Check battery voltage across the terminals, as if you haven’t you may have a loose ground, and your gauge will reflect this. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
![]() Click image to enlarge ![]() Click image to enlarge So this was on the negative? After lots of messing around.... I touched the negative with the spanner by accident the immobiliser radio powered up. So I took of whatever that is above and placed the original connection how it should be ... I fired straight up!? |
Check earth strap from negative to chassis, the wires goes to the box but had a chassis earth point, mid way. Cheers
All seems to be positioned correctly..... just where the earth was mounted to the battery... seems a very non standard fitting
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17935 ![]() ![]() ![]() |
That is a form of battery master switch, presumably fitted by a previous owner for security. The idea is that removing the nut isolates the battery. They're popular amongst people with a "classic" vehicle who want a relatively discreet isolator, but personally I don't like them and you now know one of the reasons why! If you're going to fit a battery master switch then do it properly! https://www.amazon.co.uk/Isolator-Electric...16-2991854 |
