Home > Puma (Tdci) > defender wont start
Naycrx
defender wont start
Cant get Defender to start - like the immobilizer wont work - we just have flickering fuel and temp needle?
Post #1071914 21st Jul 2025 4:01pm
jst
No starter relay clicking? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1071922 21st Jul 2025 5:27pm
Naycrx
Hi, just disconnected negative... immobiliser all seems OK.... but won't start. I have just connected the old battery that's almost flat ..with jump leads and now just keeps clicking.... maybe dead battery...
Post #1071925 21st Jul 2025 5:47pm
Naycrx
Battery reading about 8v - as we have a Gauge in the dash pod
Post #1071928 21st Jul 2025 6:22pm
Ianh
That’s way way too low, you have a dead battery that either needs charging or needs replacing if won’t charge.
Do you have another vehicle you can use to jump start your defender, if it jumpstarts and runs with leads still connected then that proves it’s the battery
Post #1071930 21st Jul 2025 6:36pm
Naycrx
I have a big jump back at work - so ill try that when i get home.
Funny thing is when i connected the old battery from our shed, it then started clicking but the Volts only rose slightly- as it was pretty much dead- but it seemed to do more when connected
How Many Volts does it need to evan attempt to start?
Post #1071931 21st Jul 2025 6:41pm
Sounds like you have parasitic drain, but could be that the battery needs replacing, or Alternator is toast.
If you charge the battery, then all is well, find out immediately if it’s parasitic drain or alternator failing to produce charging current voltage.
If at rest and you don’t know if there is parasitic drain, or it’s not identified, leave the battery disconnected or you will get a dead battery again.
Has any work been done on it recently?
Check battery voltage across the terminals, as if you haven’t you may have a loose ground, and your gauge will reflect this. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1071937 21st Jul 2025 7:35pm
Naycrx
So this was on the negative?
After lots of messing around.... I touched the negative with the spanner by accident the immobiliser radio powered up. So I took of whatever that is above and placed the original connection how it should be ... I fired straight up!?
Post #1071949 21st Jul 2025 10:30pm
