Home > Puma (Tdci) > 2014 turbo blown - fragments of metal in sump
Beeder
Hi I would appreciate some guidance if possible please
Travelling on M6 last week no concerns at all. My dog in the back starting making some really uncomfortable and not normal noises so we pulled off - luckily at the next junction that wasn’t too far away.
As soon has I stopped at the slip road roundabout I lost power and there was a loud knocking ( from the turbo ) . Turns out it had blown internally quite badly
We Got recovered back to a reputable garage and decided to change the turbo, inter cooler and oil pump with new pipes etc.
Received an email today showing some large bits of metal in the sump.
I think im happy the metal is not bottom end related as the truck still turned over and ran ok - is that a correct assumption ? Should I assume the fragments are from the turbo ? And whats the best way to proceed ?
Don’t want to spend several thousand only for the engine to go on me.
Just flush the engine or dies it need stripping ?
Appreciate any advice
Many thanks Beeder
Post #1071686 18th Jul 2025 4:59pm
Dinnu
I cannot think how fragments of the turbo - which is part of the intake system can reach to the sump.
Usually bits of the turbo get stuck in the intercooler... worse case they are ingested and potentially cause valve damage or scratch the bore. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1071693 18th Jul 2025 6:54pm
jonny
There's an oil feed to the turbo which will drain into the sump...
Post #1071695 18th Jul 2025 7:05pm
I agree with Dinnu. The only connection between turbo and sump is the small oil drain pipe from the turbo and nothing large can get down that. Anything passing from turbo to sump via the induction system would have to pass through the intercooler, inlet manifold, past the valves, then somehow get past a piston into the sump, so that's not going to happen.
The fragments in your sump will have been the aftermath of the event that caused the turbo failure, not the other way round. Something major has failed and debris, probably in the lubricant, has then destroyed the turbo.
I'm afraid it's new engine time. Crying or Very sad
Post #1071696 18th Jul 2025 7:11pm
jonny
I think it depends how 'large' 'large' is - it's pretty subjective. Did they send pics?
It should be fairly obvious if it's bigger than would fit through the oil drain, and if they have the sump off to clean it all out they should be able to inspect the bottom end, and it's not too much work to pull the rocker cover off and inspect the top end too..
Post #1071699 18th Jul 2025 7:49pm
Can you post the pictures you were sent? It might be possible to identify the fragments.
Post #1071707 18th Jul 2025 10:12pm
Siwynne
If the sump is off remove the oil pump and split it. If it’s a 2.2 style vaned pump and it has failed (it will be obvious) then it’s engine rebuild time I’m afraid. Look in the plastic oil pick up tube for more clues. The mesh strainer will hold metal fragments.
More likely an oil pump failure if a 2.2 leading to a turbo failure. Knock will likely be a melted piston.
Post #1071775 20th Jul 2025 8:44am
steve E
Wales
I had the same thing happen on my 08 2.4
Was advised to replace the engine.
Cost £8200 by Landrover specialist.
Only a 12 month warranty on the new engine.
Post #1071808 20th Jul 2025 4:03pm
Beeder
Hi thank you for the replies - i thought i had uploaded the pictures they sent me
ive tried gain
Post #1071866 21st Jul 2025 10:23am
The debris in your second and third photos would be capable of passing down the turbo-to-sump drain pipe which is actually good news since it might mean that the damage is localised to the turbo. The fragment in your first photo I am not so sure about (it is I suppose possible that it has been there since new and is a red herring).
The first fragment is frustrating since it is large enough to be recognisable but I can't at present think what it is.
Post #1071869 21st Jul 2025 10:35am
landy andy
The course finish of the metal in the first pic possibly indicates it as cast metal. Would you agree @Blackwolf
Post #1071882 21st Jul 2025 11:55am
It certainly looks that way in the photo. It a pretty big chunk of something too, but it doesn't scream "turbo" to me.
Post #1071892 21st Jul 2025 1:02pm
landy andy
No. I can’t see cast parts of the turbo making it down the oil drain.
Post #1071894 21st Jul 2025 1:27pm
Siwynne
With metal in the sump you are going to need to rebuild anyway as they will have effected bearing surfaces. Get the head off and check pistons and cylinder bores
Post #1072991 8th Aug 2025 10:43am
TexasRover
Could that top picture be a piston ring fragment? Looks a little too big bu the shiny v dull surface kinda matches a piston ring.
Post #1073007 8th Aug 2025 4:21pm
