Home > Technical > Looking for remote control item
WILLOW68
My neighbour has asked me to purchase him another remote control from eBay for his 2011 Defender.
I’ve seen a few that are like new & a fraction of the price of the new item.
His friend at work said he has a programmer so just go get yourself the remote & come to me but before I order one I’m looking for some advice towards me having to do anything to it before his mate tries to pair it with his vehicle.
Thanks.
Post #1071354 13th Jul 2025 6:11pm
Ianh
If it’s a genuine Lucas fob, designed to work with a defender 10AS ( or latter ALM CHxxxxx unit) , I.e correct frequencies etc ( look at existing ones to confirm) and it’s not just the plastic case. Then a diagnostic tool such as a Nanocom will be able to register it with your 10AS or ALM CHxxxxx Alarm ECU.
Ps a 2011 will have a 10AS from factory, not a ALM CHxxxxx.
Post #1071358 13th Jul 2025 6:24pm
WILLOW68
Hi,
I believe the tool my neighbour said he had was a Nanocom.
The item on eBay is a used circuit board in a new condition case.
The pcb had 3TXD on it.
Was advised it’s 433 MHz
My concern was as it’s used would it programme straight in or do I / we need to say “ clear it’s memory “ etc from vehicle it was taken from ?
Thanks.
Post #1071359 13th Jul 2025 6:29pm
Ianh
You don’t have to clear from original vehicle 10AS , just program to your 10AS.
Post #1071360 13th Jul 2025 6:33pm
WILLOW68
Thanks very much for that.
Post #1071361 13th Jul 2025 6:34pm
Ianh
Note that when adding a new fob you need to re-add existing fobs at the same time.
Post #1071364 13th Jul 2025 6:43pm
WILLOW68
Thanks.
I did mention to him that I’m sure the original working remote is say deleted & when you press button on new remote you then also have to do the same to original remote.
I made an error with this.
Neighbour doesn’t use pc or phones etc & that’s why he asked me to order one for him.
He’s gone away & I assumed these were all the same but eBay seller said the board is marked 3TXD
So know I’m thinking why didn’t I take my neighbours out before he went away.
Can you advise if 3TXD is correct or do I need to wait until he comes home ?
Post #1071366 13th Jul 2025 6:48pm
Ianh
You really need to check the number on the existing remote and get the same
Post #1071375 13th Jul 2025 7:42pm
WILLOW68
Ok
Post #1071377 13th Jul 2025 7:50pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Beware the aftermarket versions - in my experience they eat batteries and the batteries are not widely stocked anywhere. Have a look here -
https://www.remotekey.co.uk/category/land-rover/defender/
In this case I would say it's money well spent.
Post #1071412 14th Jul 2025 4:06pm
WILLOW68
The item is a USED circuit board placed into a new case.
It’s not a new Chinese or aftermarket item.
It s a genuine circuit board taken from a dead defender
Post #1071414 14th Jul 2025 4:19pm
Penfold_6290
Ah, in that case as you were!
Post #1071415 14th Jul 2025 4:21pm
WILLOW68
Do you have a remote that you could pop the case open and confirm the circuit board reads 3TXD
Thanks.
Post #1071416 14th Jul 2025 4:22pm
Penfold_6290
Sadly my comments about lousy aftermarket fobs is forged by bitter experience, my fobs are both fakes Sad
Mine say XP17 V1.7
Post #1071418 14th Jul 2025 4:24pm
Penfold_6290
Looking on the Remote Key website they state 433MHz is for the Euro market and the UK version is 315MHz
Post #1071419 14th Jul 2025 4:29pm
