![]() | Home > Technical > Looking for remote control item |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2428 ![]() ![]() |
If it’s a genuine Lucas fob, designed to work with a defender 10AS ( or latter ALM CHxxxxx unit) , I.e correct frequencies etc ( look at existing ones to confirm) and it’s not just the plastic case. Then a diagnostic tool such as a Nanocom will be able to register it with your 10AS or ALM CHxxxxx Alarm ECU.
Ps a 2011 will have a 10AS from factory, not a ALM CHxxxxx. Last edited by Ianh on 13th Jul 2025 6:30pm. Edited 1 time in total |
WILLOW68 Member Since: 13 Jul 2025 Location: Weston Posts: 10 ![]() ![]() |
Hi,
I believe the tool my neighbour said he had was a Nanocom. The item on eBay is a used circuit board in a new condition case. The pcb had 3TXD on it. Was advised it’s 433 MHz My concern was as it’s used would it programme straight in or do I / we need to say “ clear it’s memory “ etc from vehicle it was taken from ? Thanks. |
You don’t have to clear from original vehicle 10AS , just program to your 10AS.
Thanks very much for that.
Note that when adding a new fob you need to re-add existing fobs at the same time.
Thanks.
I did mention to him that I’m sure the original working remote is say deleted & when you press button on new remote you then also have to do the same to original remote. I made an error with this. Neighbour doesn’t use pc or phones etc & that’s why he asked me to order one for him. He’s gone away & I assumed these were all the same but eBay seller said the board is marked 3TXD So know I’m thinking why didn’t I take my neighbours out before he went away. Can you advise if 3TXD is correct or do I need to wait until he comes home ? |
You really need to check the number on the existing remote and get the same
Ok
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 387 ![]() ![]() ![]() |
Beware the aftermarket versions - in my experience they eat batteries and the batteries are not widely stocked anywhere. Have a look here -
https://www.remotekey.co.uk/category/land-rover/defender/ In this case I would say it's money well spent. |
The item is a USED circuit board placed into a new case.
It’s not a new Chinese or aftermarket item. It s a genuine circuit board taken from a dead defender |
Ah, in that case as you were!
Do you have a remote that you could pop the case open and confirm the circuit board reads 3TXD
Thanks. |
Sadly my comments about lousy aftermarket fobs is forged by bitter experience, my fobs are both fakes
![]() Mine say XP17 V1.7 |
Looking on the Remote Key website they state 433MHz is for the Euro market and the UK version is 315MHz
