Home > Maintenance & Modifications > Differences between 200tdi vs 300tdi/td5 steering box
Kai3747
Cyprus 2001 Defender 110 Td5 DCPU Auto Bonatti Grey
Hi i just removed the steering box of my Defe 2001 td5 crew cab 110 cause leaks. I disassembly it and took it to a defender specialist for rebuilt it as it had some corrosions. After he rebuild it he asked me from what car is as this steering box is from 200tdi he told me:( i never mentioned before the model of my car:) Now he told me not to put it back and to put a newer one as 300tdi and td5s are lighter and also on shaft has 3 bearings… can you help me please if he is right? Here are some pictures:
Post #1070845 4th Jul 2025 4:52pm
jst
Td5 should be 4 bolt. Hp fittings are different if yours isint 4 bolt but I expect it is.
Either way other than the leak if you were happy with it before then refit it. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1070849 4th Jul 2025 5:59pm
Kai3747
4 bolts are all. 200tdi, 300tdi and td5. Please look the pictures i uploaded before
Post #1070860 4th Jul 2025 8:20pm
jst
I don't see any pics here. Was just trying to help. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1070863 4th Jul 2025 9:01pm
Kai3747
Hi again thanx a lot:) here are more pictures
Post #1070865 4th Jul 2025 9:08pm
Dinnu
He is almost right.
The earlier 4 bolt boxes have bushes instead of needle bearings. But I doubt if the needle bearings make it lighter or better.
Here is a link to my rebuild.
https://www.defender2.net/forum/topic79246.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1070895 5th Jul 2025 12:06pm
