![]() | Home > Maintenance & Modifications > Differences between 200tdi vs 300tdi/td5 steering box |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8463 ![]() ![]() ![]() |
Td5 should be 4 bolt. Hp fittings are different if yours isint 4 bolt but I expect it is.
Either way other than the leak if you were happy with it before then refit it. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Kai3747 Member Since: 16 Oct 2021 Location: Nicosia Posts: 15 ![]() ![]() ![]() |
4 bolts are all. 200tdi, 300tdi and td5. Please look the pictures i uploaded before
I don't see any pics here. Was just trying to help. Cheers
Hi again thanx a lot:) here are more pictures
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3639 ![]() ![]() ![]() |
He is almost right.
The earlier 4 bolt boxes have bushes instead of needle bearings. But I doubt if the needle bearings make it lighter or better. Here is a link to my rebuild. https://www.defender2.net/forum/topic79246.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
