Home > Tdi > 200 TDi not starting
Procta
Last week my parents went out to view a car for my sister,
They never even got down the road, when the motor starting losing power and cutting out. They bailed back home, but ended up breaking down, so i had to tow them back home.
Me and my dad have changed the following items as we suspect its fuel related issue.
The fuel pump Solenoid and the lift pump, when we removed the old lift pump and pipes we found that the system was dry, as though the car had ran out of diesel, which the tank is half full.
Can we hell get the any fuel through the lift pump at all, no matter which way we rotate the engine, it isn't picking up any fuel at all, We have even tried to crank the car to the point its just flatting the battery like. I am suspecting that the fuel line has failed as we later discovered a cut off solenoid in the main line, which we have removed and its still the same. We have cracked off the top bleed screw on the filter housing, so that air can escape.
Me and my dad have spent a few hours trying to prime the system,
The nightmare of nightmares, is that they are going away with the caravan a week today!
is there anything you lads can suggest we can do Just to get the system to pick up diesel and get it to run again? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #1070454 27th Jun 2025 10:37pm
julian
United Kingdom 1994 Defender 110 300 Tdi CSW Alpine White
No point in constantly cranking it. Just use the lift pump manual lever. You can feel if there is tension or not.
Also, take the inlet off the lift pump and put your thumb over the end whilst you pump them manual lever. You will be able to hear a tiny pop when you pull your thumb off IF the pump is good and off the cam.
Once that's confirmed, nasty as it is, at this stage I'd suck on the pipe that comes up from the tank. I'm not telling you to do this or anyone else to do it etc.etc but it would tell you if the pipe was working.
If it isn't, that's your issue. I would use clear nylon pnumatics pipe (you can get it off eBay in all different diameters) with compression fittings and brass inserts to stop the pipe collapsing (although you can get away with not doing so if you really have to).
Post #1070464 27th Jun 2025 11:41pm
landy andy
Been years since I worked on Tdi.
Is fuel cut off solenoid working / got power to it. That would be where I start. If that was definitely working then fuel line off before pump /solenoid and as above try sucking diesel through, or using a compressor and a rag, put some air pressure into tank and get fuel out of main line. How old does filter look?
My initial looking would definitely be cut off solenoid.
Also something to think about, is that the gauge SHOWS you an amount of fuel, but is it correct ?
Post #1070465 28th Jun 2025 5:13am
Will@LRW
 1997 Defender 110 300 Tdi CSW Alpine White
Other thoughts:
Replace fuel filter?
With a firm lift pump lever you should be able to get fuel coming out of the filter bleed screw in a minute or so.
Also stick 5L of diesel in just to be sure.
Check for perished leak off pipes letting air in LR Workshop
New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners
Find a Defender's history and spec: https://defender.lrworkshop.com
Post #1070486 28th Jun 2025 12:11pm
paul 123
United Kingdom 1995 Defender 90 300 Tdi HT Auto Rutland Red
take the filler cap off it could be a simple case of blocked breather.
Post #1070503 28th Jun 2025 4:53pm
Procta
well for some reason the new pump isn't picking up fuel at all, and the fuel lines are dry. I am seriously thinking that it hasn't got enough diesel in, but my mam recons she filled this up full a week before it all went tits up like. I have put a manual hand pump thing on the fuel line to see if we can get anything from the tank, ( suck something through) and we are getting Censored all.
I am starting to wonder if the fuel float has stuck, and the fuel lift pump bit the dust at the same time.
My dad recons someone has been at the system and syphoned diesel out of it, but i cannot see it happening. Its either got a drink problem, or my parents have thought its had more fuel in it due to the gauge not moving hardly, and they have been just topping the tank up here and their, But its been the fuel float jammed. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #1070879 5th Jul 2025 12:42am
Procta
Will@LRW wrote:
Other thoughts:
i am starting to think this hasn't got enough diesel in the tank at all, as mam is hell bent saying it was filled up a week before this went on the blink, and i have just tried to get some fuel from the tank, with a hand pump there, and i am getting Censored all. so i think something may have stuck like Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #1070880 5th Jul 2025 12:44am
Procta
well we are getting the pop sound, and i have tried the suck methord from the tank with a little pump thing, i am suspecting that this may have a major fuel problem and the fuel gauge has stuck on the full marker. But mum is admint that she filled this up like, but i am suspecting that there isnt enough fuel in it. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #1070881 5th Jul 2025 12:47am
jst
Am i missing something here? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1070884 5th Jul 2025 5:56am
landy andy
As I said above. Wack some fuel in it. Simple things first.
Post #1070886 5th Jul 2025 6:55am
paul 123
i would put a good amount in like about 20 liters just to be sure then leave the cap off and try to bleed it.
Post #1070907 5th Jul 2025 4:54pm
Procta
my dad has decided to make a new fuel line up, due to the original one been cut etc, he has lost the bloody fixing for the tank end, are these just a standard brake line end? When he was adding the end it pinged off into the workshop somewhere Rolling Eyes Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #1071207 11th Jul 2025 3:12am
paul 123
while you have the pipe off get a can of diesel and a piece of pipe then extend the car pipe so its in the can . then see if it will start after bleeding it.
Post #1071211 11th Jul 2025 6:03am
Procta
found the line, and its now on the replacement pipe. I fitted the end this time Thumbs Up
We installed it, and chucked 20 litres of diesel in it, you can hear the tank was practically empty like, as it was going in. I un did the fuel bleeder, and gave it a prime, and diesel started to come out of there, which was a massive step forwards, locked that off, and gave it one more prime, and my dad fired it over and it sprang into life and Terred over as normally, maybe a little better if anything.
After watching a Britannica Restorations video on these pumps, i recon its been chucking the diesel out of the bottom old fuel lift pump, and fuel sender unit is stuck. Thumbs Up
Just a word of warning though lads, some of the fuel lines for 200 Tdi and 300 TDi are discontinued. The one from the lift pump to the fuel filter housing for the 200 TDI is discontinued, a long with the main fuel line from tank to lift pump. for the 90. the 110 you can still get. So if you have a split in the main line. you will have to make these up sadly. its a 1/4 8mm pipe my dad used for the tank to fuel lift pump. Thumbs Up
For the lift pump to fuel filter, there is a braided hose replacement, but if you can make one up your self using bits from the old unit, better off doing so, for the sake of the price. Thumbs Up
My dad may swop it for a braided unit, but we will have to see on that one Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #1071253 11th Jul 2025 7:43pm
jst
So faulty sender and it needed fuel. Simple fix. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1071265 11th Jul 2025 10:16pm
