![]() | Home > Technical > Drivetrain Vibration |
8619simon Member Since: 05 Nov 2016 Location: North Wales Posts: 264 ![]() ![]() ![]() |
Other areas other than transfer box to check would be:
Wear on the Tyres - uneven wear of the tread can cause this - could try swapping rear wheels for front see if that changes anything Bent track rod or panhard rod Loose or worn track rod ends Loose drop arm Worn swivel bearings |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6047 ![]() ![]() |
Got a mate with same vehicle??
Swap the rear prop for a test. I think that is the problem |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 600 ![]() ![]() ![]() |
Sounds like the rear prop. Perhaps it was noisy before the t/c rebuild but sound was absorbed by the general wear of the old t/c? I assume that the original or correct replacement mounts have been fitted? 1983 110 automatic OM606
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6039 ![]() ![]() ![]() |
I recently replaced my rear prop as the MOT noticed a bit of play. Driveline feels better now.
The UJ at the diff end didn't feel right and had a bit of a flat spot. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
