Home > Technical > Drivetrain Vibration
QuintinC
South Africa 2003 Defender 90 Td5 SW Alpine White
Hello Experts,
I have just had the transfer box of my 110 pick up replaced. The vehicle now had a vibration between 60 and 75 km/h (37 -47 mph).
I have checked the balance of the tire balance - all good;
The propshafts have been balanced - all good;
The phasing of the propshafts is good, all arrows aligned;
If I remove the rear Propshaft, the vibration disappears.
What could be causing this? 2003 Defender 90 TD5 SW
1989 Land Rover 110 19J Turbo Diesel PU
Post #1070375 26th Jun 2025 4:52pm
8619simon
Wales 1995 Defender 110 300 Tdi CSW Epsom Green
Other areas other than transfer box to check would be:
Wear on the Tyres - uneven wear of the tread can cause this - could try swapping rear wheels for front see if that changes anything
Bent track rod or panhard rod
Loose or worn track rod ends
Loose drop arm
Worn swivel bearings
Post #1070376 26th Jun 2025 5:22pm
landy andy
Got a mate with same vehicle??
Swap the rear prop for a test. I think that is the problem
Post #1070386 26th Jun 2025 7:04pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
Sounds like the rear prop. Perhaps it was noisy before the t/c rebuild but sound was absorbed by the general wear of the old t/c? I assume that the original or correct replacement mounts have been fitted? 1983 110 automatic OM606
Post #1070396 26th Jun 2025 11:09pm
excossack
I recently replaced my rear prop as the MOT noticed a bit of play. Driveline feels better now.
The UJ at the diff end didn't feel right and had a bit of a flat spot. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1070428 27th Jun 2025 2:37pm
