![]() | Home > In Car Electronics > CarPlay Apple Maps - Dash View |
| Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1141
No unfortunately. I have the same issue. It’s very limited on the dash display.
What I have noticed is that the orientation changes on the dash according to whether you’re viewing the map on the pivi screen or not. I always have the pivi set to direction of travel up, and the dash always displays opposite way ie North up. Go to the Home Screen and it changes the dash to dot up! 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
| seb101 Member Since: 30 May 2025 Location: UK Posts: 12
How entirely frustrating. Is it any better with Google Maps? Haven't had chance to try yet.
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
Have you considered using a different App for maps? ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6053
On my head unit it shows the next turn on the map screen
Click image to enlarge I can also keep phone showing just instructions (mounted beside head unit for me ) Click image to enlarge |
Google maps is dire via apple play. It put the vehicle in a very odd place on the screen.
Sometimes it’s glitches or a miss match between iOS versions and or App update, though.
That being said, you can have both updated and a new glitch appear. Though I don’t use the Apps mentioned here, I found it wouldn’t be uncommon if you had it set up to receive a phone call and that would knock out the sat nav, and even if you end the call etc it’d still have it knocked out and the sat nav wouldn’t revert back to use. That would mean literally having to pull over and set it up again just because of an incoming phone call. That has been ironed out with updates, you can report issues or suggest bug fixes one some systems. Though finding the menu to do that might take some time even on the phone on a site for it. It’s usually there somewhere on their web site but actually finding it can be a real pain. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
