![]() | Home > Maintenance & Modifications > Indicators not working |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21009 ![]() ![]() |
Probably the rear lighting loom ground stud loose and the associated ground eyes, it’s on the side of the transmission.
It’s a common fault as it’s common ground in my opinion, switching on the hazard switch, is a higher load as it switches more circuits, so the higher current draw, overcomes the high resistance, due to the loose ground. Not guaranteed but that’s my guess. If it does happen to be the issue, use a little low strength loctite like 222 if you have any, just a very small amount. As it can come loose, as it’s subject to very high vibration and harsh conditions. There is no guarantee it is that, but hopefully a high likelyhood. ![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2524 ![]() ![]() |
Was your original indicator light a standard bulb ? Have you now replaced it with an LED ? If so I expect that’s your issue.
snow_gibbon Member Since: 05 Jun 2025 Location: UK Posts: 4 ![]() ![]() |
Sadly this wasn't the issue. Thank you for your advice!
Interesting, as Ian mentioned are the LED lights or standard (incandescent). ____\We|Will|Win/___
They are incandescent.
Just in case anyone finds this thread and wants the answer... I took the defender into the shop - they told me the wiring was completely corroded and was tripping fuses.
