Home > Maintenance & Modifications > Indicators not working
snow_gibbon
Hi,
I've recently replaced a fault rear indicator in my 2015 90 XS. After the repair none of the indicators (front, side, rear, left, right) are working, but if I put on my hazards all the indicator lights flash. Any ideas?
Thanks!
Post #1069155 5th Jun 2025 8:04pm
Probably the rear lighting loom ground stud loose and the associated ground eyes, it’s on the side of the transmission.
It’s a common fault as it’s common ground in my opinion, switching on the hazard switch, is a higher load as it switches more circuits, so the higher current draw, overcomes the high resistance, due to the loose ground.
Not guaranteed but that’s my guess.
If it does happen to be the issue, use a little low strength loctite like 222 if you have any, just a very small amount.
As it can come loose, as it’s subject to very high vibration and harsh conditions.
There is no guarantee it is that, but hopefully a high likelyhood.
Thumbs Up _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1069157 5th Jun 2025 8:21pm
Ianh
Was your original indicator light a standard bulb ? Have you now replaced it with an LED ? If so I expect that’s your issue.
Post #1069190 6th Jun 2025 10:25am
snow_gibbon
Sadly this wasn't the issue. Thank you for your advice!
Thumbs Up
Post #1069270 7th Jun 2025 8:42pm
Interesting, as Ian mentioned are the LED lights or standard (incandescent). _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1069289 8th Jun 2025 1:17pm
snow_gibbon
They are incandescent.
Post #1069308 8th Jun 2025 5:32pm
snow_gibbon
Just in case anyone finds this thread and wants the answer... I took the defender into the shop - they told me the wiring was completely corroded and was tripping fuses.
Post #1069610 12th Jun 2025 10:16pm
