![]() | Home > Puma (Tdci) > Traction control in corners |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2501 ![]() ![]() |
Have you checked your wheels bearings , especially front ones.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8393 ![]() ![]() ![]() |
What do mean by bouncing into corners? If its bouncing wheels coming off the ground or weight shifting significantly then tc will.come on. Cheers
Bailey123 Member Since: 03 Sep 2023 Location: Scarborough Posts: 6 ![]() ![]() |
I will check all the wheel bearings next, thankyou.
And I just meant lightly bouncing, nothing enough to need the traction control to activate. |
The only thing I can think of causing bouncing at low speed would be something grabbing the transmission at times. Could be tc from senor issues, could be diff grabbing, handbrake although this would be evident regardless of steering input..
To be honest other than off road racing and poor shock setup I haven't heard of defenders bouncing into corners. Does yours have dsc, is steering angle set correctly? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Problem cured. Had the steering sensor re-calibrated, no longer comes up with traction control in the corners.
Thankyou very much for everyone’s advice |
![]() James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
