Home > Puma (Tdci) > Traction control in corners
Bailey123
Hello all,
Traction control keeps coming on in corners, when not going fast. It’s particularly worse when the cars sort of bouncing into the corner.
Any ideas what could be causing this? Had a look underneath and nothing seems unduly loose, or like there is excess wear in the prop
Post #1068714 29th May 2025 5:43pm
Ianh
Have you checked your wheels bearings , especially front ones.
Post #1068716 29th May 2025 6:05pm
jst
What do mean by bouncing into corners? If its bouncing wheels coming off the ground or weight shifting significantly then tc will.come on. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1068732 29th May 2025 9:29pm
Bailey123
I will check all the wheel bearings next, thankyou.
And I just meant lightly bouncing, nothing enough to need the traction control to activate.
Post #1068747 30th May 2025 7:28am
jst
The only thing I can think of causing bouncing at low speed would be something grabbing the transmission at times. Could be tc from senor issues, could be diff grabbing, handbrake although this would be evident regardless of steering input..
To be honest other than off road racing and poor shock setup I haven't heard of defenders bouncing into corners.
Does yours have dsc, is steering angle set correctly? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1068748 30th May 2025 8:14am
Bailey123
Problem cured. Had the steering sensor re-calibrated, no longer comes up with traction control in the corners.
Thankyou very much for everyone’s advice
Post #1071911 21st Jul 2025 3:44pm
jst
Thumbs Up good to hear its resolved. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1071921 21st Jul 2025 5:14pm
