Home > Puma (Tdci) > ABS issue Defender 2.2 Puma
Toucanspeed
United Kingdom 2015 Defender 90 Puma 2.2 CSW Indus Silver
Occasionally as i slow to a stop from maybe 2-3mph, the ABS pump can be heard running. I dont think any wheel is slipping. There are no lights on the dash, brake fluid is full, everything else appears to work fine. I thought it was the nearside front wheel (because of where the vibration came from - probably just the pump) I took the sensor out and it drained the oil from the hub, is this normal?
Any pointers would be appreciated.
TIA.
Post #1066356 26th Apr 2025 10:37am
andy63
When you say no faults , do you see any lights flashing on the dash while the pump is operating..I think that would be normal , but again just from memory.. I'm sure I've seen my stability control light flashing when the traction controller kicks in and think I've seen similar when the abs is working..
Can only think that the abs is seeing a wheel signal that is indicating a lock up and actuation..
Could only suggest a check of all the wheel sensors and if you had access to a tool that showed live data for the abs ecu...
Post #1066525 28th Apr 2025 1:02pm
Toucanspeed
No warning lights at all. Abs and stability appear to work fine other than the pump running when braking at 2-3 mph occasionally. I’ve measured all the resistance of the sensors and they appear ok. What diagnostic program do I need?
Post #1066537 28th Apr 2025 3:00pm
andy63
The other factor is the air gap or state of the reluctor ring,( cracked etc ) even though the sensor coil itself appears OK..
This was touched on the other day.. Ian pointed out that the standard obd protocol did give codes for abs, but you have no visible faults logged and I'm suggesting that you need a scan tool that is capable of live data from the abs ecu.. even then I'm not sure what it would actually show..and again I'm not at home to try my tool..
I use a scope usually.. that is capable of looking at the signals generated at the wheel sensors and showing any anomalies that the ecu would react to...
Post #1066539 28th Apr 2025 3:19pm
Why do we do it
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Aintree Green
I know this post is a few years old now, but did you get a resolution for your ABS issue as I have a similar problem with my puma 2.4 which I can’t seem to track down all electrics seem good but the pump seems to trigger at very low speeds when you press the brake pedal.
Post #1069445 10th Jun 2025 7:29pm
Ianh
The 2.2 and the 2.4 use completely different ABS solutions. The 2.4 is Wabco and the 2.2 is Bosch.
Do a search on Wabco and you will likely find a topic that covers your issue.
Post #1069458 10th Jun 2025 11:22pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
The sensors are known for being slightly different distances from the reluctor wheel. This leads to differing readings at slow speeds, and, the sensors "starting up" at different speeds. This can give the symptoms above. You need a tool that reads the sensor voltages in real time. You can then have them all up on the screen and quickly tell which one is lagging. On a D2. believe it or not, a tap with a hammer can cure a lagging sensor. The blow knocks it in just a wee bit further, curing the problem.
Please do not just go and start whacking your sensors. Do the diagnostics first!
Post #1069463 11th Jun 2025 1:11am
andy63
Ahh i see i posted on this when I was away from home..
I'm home so let me explain..
Ive said before a generic obd reader will only lift abs codes if it has some non generic..ie manufacturer capability..
I don't think you can view any obd code that doesn't start with the first didgit been a one...
0 indicates generic and a 1 manufacturer..
So you do need a reader that has that capability ..
The puma network is only 3 modules..
The powertrain ecu, the instrument cluster, and the abs module..
They are networked by can bus..
Plug your tool in and select the abs module.. and basically follow the instructions till you can view the live abs module data or as much of it as your tool can access..
To diagnose your issue that's where you need to start IMHO..
Anything else is just guesswork and you might get lucky..
A little walk through with photos..
Not sure what order they will appear in but here is what i can access with an old scan tool.. and as I'm not driving the wheel sensors are reading 0 kmh
Post #1069475 11th Jun 2025 9:32am
macfrank
Re: ABS issue Defender 2.2 Puma
Has anyone noticed this remark? I find this strange in two ways: a) the sensor is mounted on top of the hub, so how should anything drain b) there should be no oil in a 2.2's hub but grease
Post #1069493 11th Jun 2025 12:01pm
andy63
Yes.. I wondered about that.. and couldn't make sense of it..👍🤔, but obviously forgot to mention in my reply..
Post #1069494 11th Jun 2025 12:06pm
jbcollier
The fill plug is pretty high up. If someone thought the fill plug was also the level plug, you could get a lot of oil in there. Which, would then partially drain when you removed the sensor.
Or, you are checking the sensors with the truck inverted...
Post #1069509 11th Jun 2025 2:01pm
macfrank
"Or, you are checking the sensors with the truck inverted..." I think that's it Rolling with laughter
"The fill plug is pretty high up."
That fill plug is still lower than the sensor. Also the 2.2's hub doesn't have a level plug since they've replaced oil with grease.
Even if the hub seal had given in, flooding the hub with axle oil, I don't think there's enough oil in there to get up to the sensor. The diff's fill/level plug is at bit below the centre of the axle.
Post #1069514 11th Jun 2025 2:16pm
jbcollier
Dunno when the change occurred but my 2009 2.4 also only has the single, higher placed, fill plug.
Post #1069515 11th Jun 2025 2:31pm
jst
2.4 wabco to 10my then they are bosch systems.
I had similar issues with mine. Didn't always do it but increased chance of doing it in the wet. Slow speed, under braking abs pump heard running, no indicator symbols.
Mine turned out to be resolved by cleaning up rear loom connectors. (After alotnof other sensor seating related checks) Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1069516 11th Jun 2025 3:05pm
Toucanspeed
I’m glad someone spotted it in my original post. I guess the previous owners put this in. It was last serviced by AstonMartin dealership(owners company. You’d think they’d know better. I presume I can just drain this out and fill with one shot. Neither of the hubs are leaking. At the same time I’ll check the abs reluctor rings and hopefully push the abs sensors in (although they appear fixed to their brackets). I was wanting to measure the sensor output which I guess I can do with the foxwell system (what model is it please). Although I’m not new to Defenders it’s my first puma and it’s a
Little different from the td5 I had. Is it worth investing in a ncom03 or will the foxwell do 99% of what I’m likely to need. Nanocom comes in at nearly £500
Post #1070043 20th Jun 2025 10:01am
