Home > Technical > Ratio change with ATB?
LJMARSDEN
United Kingdom 2006 Defender 90 Other HT Java Black
Evening all,
Is it possible to alter the gear ratio in the LT230 at home even if you have an ATB installed already?
I have a Winchester gears stage two but I’ve since gone from an R380 to a ZF GS6. And of course now it’s cruising a bit high.
Would I encounter an issue?
 4.0 V8 Defender 90
My Instagram
Post #1066304 25th Apr 2025 7:44pm
The ATB will make no difference to a ratio change. If you are a competent gearbox mechanic it is an easy job.
Post #1066306 25th Apr 2025 8:31pm
LJMARSDEN
That’s good, I’ll get a gear set ordered.
I’ve done an engine rebuild and conversion so I should be gravy doing this to be fair. 4.0 V8 Defender 90
My Instagram
Post #1066366 26th Apr 2025 12:04pm
ashtrans
Site Sponsor
see the 'installation' tab here :
https://ashcroft-transmissions.co.uk/product/1-222-gear-set/
Dave Dave
Post #1066757 1st May 2025 10:42am
LJMARSDEN
Thank you for that 4.0 V8 Defender 90
My Instagram
Post #1066790 1st May 2025 10:21pm
