![]() | Home > Technical > Ratio change with ATB? |
LJMARSDEN Member Since: 08 Jun 2021 Location: Nottingham Posts: 350 ![]() ![]() ![]() |
Evening all,
Is it possible to alter the gear ratio in the LT230 at home even if you have an ATB installed already? I have a Winchester gears stage two but I’ve since gone from an R380 to a ZF GS6. And of course now it’s cruising a bit high. Would I encounter an issue? ![]() Click image to enlarge 4.0 V8 Defender 90 My Instagram |
That’s good, I’ll get a gear set ordered.
I’ve done an engine rebuild and conversion so I should be gravy doing this to be fair. 4.0 V8 Defender 90 My Instagram |
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 264 ![]() ![]() |
see the 'installation' tab here :
https://ashcroft-transmissions.co.uk/product/1-222-gear-set/ Dave Dave |
Thank you for that 4.0 V8 Defender 90
My Instagram |
