Home > Maintenance & Modifications > Wiper motor
L110CDL
Wiper motor
So on my way back from my eldest daughters this morning in the poring rain, my original 29 year old wiper motor decided to stop working leaving my wipers in the vertical position on the windscreen Rolling Eyes
The wiper motor has done well, so i'm asking the community were would be the best place to purchase a new one please as this is a first for me, 1996 MY.
TIA
Very Happy Clayton.
Keeper.
Post #1065801 18th Apr 2025 8:20pm
revd
Code FLASH20 for 20% off JLR Classic parts this weekend
https://parts.jaguarlandroverclassic.com
Probably still just as expensive as genuine parts at Rimmer Bros
Post #1065804 18th Apr 2025 8:42pm
L110CDL
Thanks for the link revd Thumbs Up Clayton.
Keeper.
Post #1065807 18th Apr 2025 8:46pm
L110CDL
Iv'e just had a look on JLR classic and they don't do the wiper motor, so i went onto Rimmer brothers and i had a big shock, genuine wiper motor is around £300 and a aftermarket wiper motor is around the £100 mark, i know going genuine is the way to go, at this price, is it ? Clayton.
Keeper.
Post #1065808 18th Apr 2025 8:58pm
donmacn
I was in exactly the same position not so long ago. Original motor stopped working (though as I get older…. I can’t remember what the symptoms were!)
Although I’m increasingly going for genuine these days if it’s sensible, I know I didn’t pay £300 for the replacement so I’m assuming I went for non-genuine. Been on a couple of years I think, with no issues.
I kept the old one and took it apart. Though I don’t really know much about these things, it looked like a new set of brushes might have been all that was needed, so I’ve kept it on the shelf and will maybe look again if the need arises.
The genuine vs aftermarket is always a difficult question, though for me personally £100 vs £300 would probably swing it!
(Edit - not trying to teach Clayton to suck eggs… but I assume you’ve checked the motor itself and it’s not anything like seized wiper boxes, relays, fuses etc?) Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #1065831 19th Apr 2025 8:43am
revd
All genuine 'Lucas' parts, inc switch gear etc are very expensive now
No wonder Britpart keep going
If the job is a pig, to save doing it twice I would normally tend to go for genuine but I'm wary now of paying for a green oval on the box only to find the contents are indistinguishable from pattern parts.
Anyone here have any experience of the cheaper option?
Post #1065844 19th Apr 2025 11:23am
Retroanaconda
Definitely worth stripping the motor before buying new. They’re not complicated things, and as above a new brush set might be all it needs.
Post #1065847 19th Apr 2025 12:04pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Thinking outside the box, isnt the defender just leyland parts bin technology? Its a common wiper motor fitted to other cars, like the mini column switches and mini interior door handles. The wiper motor in my mini looks identical, and minispares sell one made by the original manufacturer for £49.80inc vat, you just have to put your gear in from the old one. 1953 80"
1987 mini city e
2011 90"
Post #1065903 19th Apr 2025 9:21pm
paul 123
United Kingdom 1995 Defender 90 300 Tdi HT Auto Rutland Red
when you put the gear in make sure its the right way or you end up with lhd wipers. also some new motors need changing.
Post #1065909 20th Apr 2025 7:28am
Lucas is pretty decent normally, often LR Genuine anyway.
Just fresh grease and everything lubed up can make a heck of a difference, the wheel boxes and rack can as good as seize up on its own.
On mine the Motor was the only thing I didn’t replace, but when everything else was done it was like new so was causing the motor to labour w lot being all gummed up, plus noise as well.
In good working order, wipers should be relatively quiet.
In summer, I now use the wipers occasionally with washers every now and then, even at the expense of a little washer fluid.
As in long spells in summer the wipers don’t get used, and this is when the grease gums up, thickens and drys, typically, then heavy rain after a long period of use and the wipers fail.
Sod’s Law dictates that might be in autumn too, and that might, be MOT time coming up, which can then be various problems rolled into one, plus raining as well when wanting to fix it. Rolling Eyes
So if possible, best to tackle that job in good weather when convenient, but of course that isn’t always possible or as predictable as that.
But the wheel boxes and rack do get gummed up in summer, so it’s worth bearing that in mind, using wipers on and off over those months, will stop that being an issue. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1065933 20th Apr 2025 5:10pm
Mo Murphy
In my experience Lucas these days is repackaged cheap tat from India and China and by no stretch of the imagination would I ever call it "quality".
50 Shades of Pennine Grey
Post #1065993 21st Apr 2025 1:44pm
L110CDL
Thank you to all the reply's Very Happy
So to update this...
I was going to buy a genuine one but they were not in stock, so i got an aftermarket one, i had to change over the gearing, cleaning and putting new grease in, i then installed it in Millie, it didn't work at first Rolling Eyes found out it was the fuse which had blown, but someone had put a 10A in where it should have been a 15A, i have put the correct one in there now, it all works Very Happy
Q. the driver's side wiper arm doesn't go all the way over to the windscreen rubber and the passenger side doesn't go to the middle, is this because it's new or have i not installed the gearing in the right position ?
TIA. Clayton.
Keeper.
Post #1066189 23rd Apr 2025 9:23pm
ak615
I'd take the wiper arms off ,switch the wipers on and allow to cycle a couple of times ,switch wipers off replace wiper arms in parked positions, switch wipers on and see if they sweep correctly.
Post #1066203 24th Apr 2025 6:44am
L110CDL
Thanks for the tip, i will hopefully have a go at the weekend sometime Very Happy Clayton.
Keeper.
Post #1066315 25th Apr 2025 9:29pm
Joeytf
Sorry to jump on this but I’m having wiper issues. My wipers aren’t moving all the way to clear I front of the driver. I’ve changed the wheels and the wipers are set in the right position just don’t get much of a swoosh.
Post #1066317 25th Apr 2025 9:32pm
