Home > Maintenance & Modifications > Swing away door carrier
BriDar85
Hi I would like to fit the Britpart swing away spare carrier to my defender. I have a bit of a placement issue for the back plate. There are no pre existing holes to guide where the plate should go. Does anyone know what the measurements should be, or how I can work out where the holes go?
Thanks in advance!
Brian
Post #1064938 7th Apr 2025 6:13pm
TexasRover
So it carries the door as it swings out?
Post #1064951 7th Apr 2025 7:09pm
BriDar85
Sorry spare wheel carrier😂🤣. It's been a long day...
Post #1064952 7th Apr 2025 7:10pm
Dinnu
This could help:
 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1064957 7th Apr 2025 8:10pm
BriDar85
I've had a look through forums and YouTube, that video is great, and I love that guy, he's funny! But my issue is that the door has no existing markings on it, from previous carrier or other. I am not sure where exactly the plate needs to be positioned. I don't know if anyone else has tried without any existing markings or holes?
Thanks for the response though!
Brian
Post #1064958 7th Apr 2025 8:15pm
TexasRover
Like in the Britannia video, don't you just "offer it up" mark the holes and drill them?
Post #1064965 8th Apr 2025 4:07am
Dinnu
Sounds you have an aftermarket door. I could measure from bottom and left/right edge of my door (later pressed steel door) just to give you an idea. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1064966 8th Apr 2025 6:03am
landy andy
The spare wheel carrier is bolted to the cross member inside the door with the bolts just going through the door skin.
So open the door, remove the inner panel and you will see the bolts go. Either measure and mark up or drill from inside to out with pilot bit.
Post #1064972 8th Apr 2025 8:46am
BriDar85
Hi that would be really helpful, if you don't mind. Thank you
Post #1065059 9th Apr 2025 12:38am
BriDar85
None of the holes in the door seem to line up with those on the carrier plate. If I install the arm first, then I could possibly offer it up, mark and drill, but that still feels like i would be guessing.
Post #1065060 9th Apr 2025 12:42am
Dinnu
Dohhh… forgot to measure. The Defender is not my daily, and parked a bit away from home… and my new to me motorcycle parked next to it is kind of taking my attention Whistle
I remember that on my old LandRover build thread there are some pictures of the rear door. On the page the below link opens you can see the external side of the door frame without the skin. You can see where the holes are located. On the following page, there are some more pictures.
https://www.defender2.net/forum/topic72365-360.html
There are 2 types of spare wheel carriers that fit older doors. The smaller one has a backing plate that fits inside that space enclosed by the door frame. Its like below.
The later ones are larger and the backing plate sandwich the frame section. I think that one has same bolt pattern as the later design. But unsure if the bolt pattern are exactly identical as most likely you have the carrier for the pressed steel door (2002 ish onwards). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1065169 9th Apr 2025 9:01pm
BriDar85
I'm pretty sure the holes I've circled in this picture will line up with some of the ones on the Britpart backplate. If you had such a plate, a quick drawing with some measurements of where the holes are would be a great help. I think that panel would fit perfectly into the section below the wiper mechanism on my door. Once I locate one, the rest should be easy!
Post #1065179 9th Apr 2025 10:26pm
Dinnu
Measurement of lower central hole from bottom and hinge side.
Post #1065239 10th Apr 2025 4:18pm
Dinnu
Measured this hole and it matches the dimensions of the old door
Post #1065244 10th Apr 2025 5:41pm
BriDar85
Hi, thank you so much for these measurements. I am sure I will be able to use them. I will post when I'm done.
Thanks again, very grateful!
Post #1065271 11th Apr 2025 8:40am
