![]() | Home > Maintenance & Modifications > Swing away door carrier |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3631 ![]() ![]() ![]() |
![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
Good to hear, even better to see actually.
Very sure you needed that wheel carrier with that rim any tyre combo. Did you have to put spacers behind the bumperette? The ones I saw interfere with the lower hinge bracket. ![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
BriDar85 Member Since: 06 Apr 2025 Location: Todmorden Posts: 9 ![]() ![]() |
I put the wheel carrier bracket on top of the bumperette(one hole matched, the one with the very long bolt) I then fabricated a spacer the same thickness as the bumperette from a few sheets of mild steel I had leftover from a welding project. Used the little backplate to position the holes, and it worked a treat. It's gone for MOT now, but when its back I'll get some close ups, it's not perfect but it does the job.
