Home > Maintenance & Modifications > Swing away door carrier
Page 2 of 2 <12
Dinnu
Thumbs Up 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1065309 11th Apr 2025 7:56pm
BriDar85
Fitted
Thank you for your help, all fitted and working perfectly! 👌
Post #1065488 14th Apr 2025 5:28pm
Dinnu
Good to hear, even better to see actually.
Very sure you needed that wheel carrier with that rim any tyre combo.
Did you have to put spacers behind the bumperette? The ones I saw interfere with the lower hinge bracket. Thumbs Up 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1065496 14th Apr 2025 6:48pm
BriDar85
I put the wheel carrier bracket on top of the bumperette(one hole matched, the one with the very long bolt) I then fabricated a spacer the same thickness as the bumperette from a few sheets of mild steel I had leftover from a welding project. Used the little backplate to position the holes, and it worked a treat. It's gone for MOT now, but when its back I'll get some close ups, it's not perfect but it does the job.
Post #1065497 14th Apr 2025 6:55pm
Page 2 of 2 <12
