Home > Puma (Tdci) > Smoke in Cab After Braking - Handbrake Stuck |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5424 |
What can happen is that the engine gearbox earth cable fails/isn’t refitted so the engine earths through the handbrake cable. Shorting it and doing what you described.
I know that doesn’t fit with all your points above, but would be my starting point. |
16th Mar 2024 9:00am |
Dorothy Member Since: 14 Sep 2020 Location: Rotherfield Posts: 18 |
Thanks Andy I will have a read about that. Can't quite understand why it happened so acutely at that particular moment of having to brake hard. I thought the ABS had died but I couldn't understand the connection to the handbrake. There I was buying a 'newer' one to avoid all the issues with the older one.
16th Mar 2024 9:37am |
Andy thank you. Largely spot on. What had happened... ( ) was that I changed the battery yesterday. Secured it to the battery tray but clearly, not well enough. Some very shoddy roads and then the sudden emergency downhill stop was enough force to send the battery forward from it's tray and it obviously earted against the front wall of the seatbox.
Now extra secure with optional lumps of 4 x 2 in situ. Mercifully, after my pride, the only casualty is the handbrake cable/etc that has earthed. What do we reckon the extent of the damage is? Everything else electrical appears to be fine. |
16th Mar 2024 10:11am |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2070 |
I had a similar issue in the past where I added a 2nd battery and pushed the original onto the battery box wall shorting out the break cable - no other electrical issues found but just my embarrassment explaining what had happened and why !!
Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
16th Mar 2024 10:32am |
So is it just a case of replace cable or will I find unpleasantness in the handbrake housing??
16th Mar 2024 10:53am |
I just had a full cable replacement (inner and outer ) and its been fine ever since - the tech who did the job said that they see this from time to time and he had caused the same to happen on a vehicle he was working on ... Ive now insulated the battery box to prevent this happening again !
16th Mar 2024 11:07am |
I think the only issue will be a new HB cable. But I’d be buying a LR one. Some a really poor quality. Also lube before you fit it
16th Mar 2024 11:32am |
