Home > Puma (Tdci) > Smoke in Cab After Braking - Handbrake Stuck
Dorothy
Last night I was heading down a steep hill when we had to stop suddenly for a deer. Glad it wasn't my TD5... Vehicle stoped well, no skidding but then an awful smell and a good amount of smoke up from the driver's floor/dash area. Smell continued for much of the 10-15min journey. On arrival I went to apply the handbrake but found it immovable.
I did notice on this 2013 XS Utility 2.2 that the handbrake felt very tight. On my TD5 to apply the handle had to be applied through the full range. On this one it was tight and a very small range of music.
I don't understand the relationship between heavy braking and handbrake?
Can a sage clarify?
I will of course go and see if the 17mm adjuster can be loosened.
Post #1028239 16th Mar 2024 8:56am
landy andy
What can happen is that the engine gearbox earth cable fails/isn’t refitted so the engine earths through the handbrake cable. Shorting it and doing what you described.
I know that doesn’t fit with all your points above, but would be my starting point.
Post #1028240 16th Mar 2024 9:00am
Dorothy
Thanks Andy I will have a read about that. Can't quite understand why it happened so acutely at that particular moment of having to brake hard. I thought the ABS had died but I couldn't understand the connection to the handbrake. There I was buying a 'newer' one to avoid all the issues with the older one. Laughing
Post #1028242 16th Mar 2024 9:37am
Dorothy
Andy thank you. Largely spot on. What had happened... ( Embarassed ) was that I changed the battery yesterday. Secured it to the battery tray but clearly, not well enough. Some very shoddy roads and then the sudden emergency downhill stop was enough force to send the battery forward from it's tray and it obviously earted against the front wall of the seatbox.
Now extra secure with optional lumps of 4 x 2 in situ.
Mercifully, after my pride, the only casualty is the handbrake cable/etc that has earthed. What do we reckon the extent of the damage is? Everything else electrical appears to be fine.
Post #1028246 16th Mar 2024 10:11am
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
I had a similar issue in the past where I added a 2nd battery and pushed the original onto the battery box wall shorting out the break cable - no other electrical issues found but just my embarrassment explaining what had happened and why !!
Thumbs Up Whistle Rolling with laughter Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #1028247 16th Mar 2024 10:32am
Dorothy
So is it just a case of replace cable or will I find unpleasantness in the handbrake housing??
Post #1028253 16th Mar 2024 10:53am
wyvern
I just had a full cable replacement (inner and outer ) and its been fine ever since - the tech who did the job said that they see this from time to time and he had caused the same to happen on a vehicle he was working on ... Ive now insulated the battery box to prevent this happening again !
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #1028254 16th Mar 2024 11:07am
landy andy
I think the only issue will be a new HB cable. But I’d be buying a LR one. Some a really poor quality. Also lube before you fit it Thumbs Up
Post #1028258 16th Mar 2024 11:32am
