![]() | Home > Puma (Tdci) > Smoke in Cab After Braking - Handbrake Stuck |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6048 ![]() ![]() |
What can happen is that the engine gearbox earth cable fails/isn’t refitted so the engine earths through the handbrake cable. Shorting it and doing what you described.
I know that doesn’t fit with all your points above, but would be my starting point. |
Dorothy Member Since: 14 Sep 2020 Location: East Sussex Posts: 55 ![]() ![]() ![]() |
Thanks Andy I will have a read about that. Can't quite understand why it happened so acutely at that particular moment of having to brake hard. I thought the ABS had died but I couldn't understand the connection to the handbrake. There I was buying a 'newer' one to avoid all the issues with the older one.
Andy thank you. Largely spot on. What had happened... (
![]() Now extra secure with optional lumps of 4 x 2 in situ. Mercifully, after my pride, the only casualty is the handbrake cable/etc that has earthed. What do we reckon the extent of the damage is? Everything else electrical appears to be fine. |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2153 ![]() ![]() ![]() |
I had a similar issue in the past where I added a 2nd battery and pushed the original onto the battery box wall shorting out the break cable - no other electrical issues found but just my embarrassment explaining what had happened and why !!
![]() ![]() ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
So is it just a case of replace cable or will I find unpleasantness in the handbrake housing??
I just had a full cable replacement (inner and outer ) and its been fine ever since - the tech who did the job said that they see this from time to time and he had caused the same to happen on a vehicle he was working on ... Ive now insulated the battery box to prevent this happening again !
I think the only issue will be a new HB cable. But I’d be buying a LR one. Some a really poor quality. Also lube before you fit it
