Home > Puma (Tdci) > Intercooler problem
Vmax
Gibraltar 2008 Defender 110 Puma 2.4 SW Baltic Blue
Intercooler problem
Does this require changing the pipe only or do l need to check more parts that could be damaged?
Post #1017879 9th Dec 2023 2:23pm
DAZ110
If one is splitting then it probably won’t be long before the other hose splits too. Better change them soon.
Post #1017886 9th Dec 2023 3:54pm
Vmax
So it's the hoses needs changing only yep.
Post #1017891 9th Dec 2023 4:08pm
Ianh
It should be just the two hoses that need replacing, one in, one out of the intercooler. Use silicon ones from Bell auto services or Allisport.
Post #1017895 9th Dec 2023 4:54pm
Vmax
Thank you very much for your help
Post #1017898 9th Dec 2023 5:16pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
If you still have trouble after changing those two, the intercoolers themselves can split at the seams & there's also a third hose low down & difficult to access going into the inlet manifold. Looks like you have the culprit in your photo though.
Post #1017906 9th Dec 2023 6:16pm
Ianh
I believe the OP has a 2.4, and therefor 2 hoses, where as the 2.2 has 3 hoses, including that difficult 90degree bend to the inlet manifold .
Post #1017907 9th Dec 2023 6:31pm
Vmax
Change three hoses.
Post #1017908 9th Dec 2023 6:31pm
Vmax
Two excellent
Post #1017912 9th Dec 2023 6:55pm
JPE
Sorry my mistake, change 2 ! Smile
Post #1017915 9th Dec 2023 7:26pm
Vmax
No worries 👍
Post #1017935 9th Dec 2023 10:06pm
