![]() | Home > Puma (Tdci) > Intercooler problem |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2064 ![]() ![]() |
If one is splitting then it probably won’t be long before the other hose splits too. Better change them soon.
Vmax Member Since: 29 Apr 2023 Location: Europe Posts: 77 ![]() ![]() ![]() |
So it's the hoses needs changing only yep.
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2425 ![]() ![]() |
It should be just the two hoses that need replacing, one in, one out of the intercooler. Use silicon ones from Bell auto services or Allisport.
Thank you very much for your help
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 343 ![]() ![]() ![]() |
If you still have trouble after changing those two, the intercoolers themselves can split at the seams & there's also a third hose low down & difficult to access going into the inlet manifold. Looks like you have the culprit in your photo though.
I believe the OP has a 2.4, and therefor 2 hoses, where as the 2.2 has 3 hoses, including that difficult 90degree bend to the inlet manifold .
Change three hoses.
Two excellent
Sorry my mistake, change 2 ! ![]() |
No worries 👍
