Home > Puma (Tdci) > Rear seat measurements
Shropshirelad
United Kingdom 2011 Defender 90 Puma 2.4 HT Zambezi Silver
I am fitting rear seats to my 90, can someone measure their seat positions. Need to work out where I am mounting them. I will be using this mat. But it’s on order. Thanks in advance.
Post #1009316 28th Sep 2023 8:47pm
geobloke
Forward facing or side facing seats mate?
Post #1009336 28th Sep 2023 10:20pm
Shropshirelad
Forward mate
Post #1009341 28th Sep 2023 10:56pm
geobloke
Roger that. Can’t help you Rolling with laughter I only have the bolt holes for the side facing seats.
Post #1009342 28th Sep 2023 11:16pm
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
0.425m or 42.5cm
Does that help.
Post #1009356 29th Sep 2023 9:35am
Shropshirelad
Legend!!
Post #1009386 29th Sep 2023 4:25pm
Snowy90
No probs, hope it helps
Post #1009704 2nd Oct 2023 10:03am
Shropshirelad
Any chance you could take a photo of where your belt mounts into the tub floor and posssibly underneath?? Trying to mount my belts but not sure where to mount them? Thanks in advance!!
Post #1009936 3rd Oct 2023 7:25pm
Snowy90
Any Good
Post #1009987 4th Oct 2023 10:09am
Shropshirelad
That’s amazing. So do the end of the belts just bolt through the floor with no bracket back to chassis? Just some sort of plate underneath??
Post #1010026 4th Oct 2023 2:43pm
Snowy90
Thats right look like they have a reinforcing plate behind and some form of stud bolt to stop them spinning.
Post #1010027 4th Oct 2023 2:46pm
Dinnu
No, there should be brackets going to the rear crossmember outriggers. Such as this one from YRM.
https://yrmit.co.uk/product/rhs-rear-seat-...-defender/
There is also a spreader plate that bolts from top of the tub to this bracket. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1010030 4th Oct 2023 3:09pm
Snowy90
Shocked Thats interesting i dont have that?
Post #1010034 4th Oct 2023 3:39pm
Snowy90
You are right, Bow down i do have something like that, its just caked in mud and hidden behind the filler tube.
So yes you do need additional brackets/bracing.
Post #1010035 4th Oct 2023 3:47pm
Dinnu
The originals tend to rust pretty quick and blend with rest of the environment 😉 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1010038 4th Oct 2023 3:50pm
