![]() | Home > Puma (Tdci) > Rear seat measurements |
Forward facing or side facing seats mate?
Shropshirelad Member Since: 28 Aug 2023 Location: Shresbury Posts: 20 ![]() ![]() ![]() |
Forward mate
Roger that. Can’t help you
Snowy90 Member Since: 23 Feb 2015 Location: Surrey Posts: 482 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge 0.425m or 42.5cm Does that help. |
Legend!!
No probs, hope it helps
Any chance you could take a photo of where your belt mounts into the tub floor and posssibly underneath?? Trying to mount my belts but not sure where to mount them? Thanks in advance!!
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Any Good |
That’s amazing. So do the end of the belts just bolt through the floor with no bracket back to chassis? Just some sort of plate underneath??
Thats right look like they have a reinforcing plate behind and some form of stud bolt to stop them spinning.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3597 ![]() ![]() ![]() |
No, there should be brackets going to the rear crossmember outriggers. Such as this one from YRM.
https://yrmit.co.uk/product/rhs-rear-seat-...-defender/ There is also a spreader plate that bolts from top of the tub to this bracket. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
You are right,
![]() So yes you do need additional brackets/bracing. |
The originals tend to rust pretty quick and blend with rest of the environment 😉 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
