Home > Maintenance & Modifications > Foam seals
ZeDefender
Foam seals
... the ones under the door frames.
Mine have fallen out after only 6 months and appear to do nothing except keep everything wet!!?
Apart from the LR muppetry of using such things (looks better in the showroom?) should I replace them with:
a) more pathetic foam tape
b) butyl tape to seal the gap and keep water from entering from above
c) nothing?
Ta very much for input,
Matt Tell someone you love them today because life is short.
Post #95215 20th Oct 2011 3:19pm
MK
Probably tape or rubber. OE part is quite cheap though. Puma 110" SW
Post #95216 20th Oct 2011 3:21pm
ZeDefender
Cheers Smile
I went for the butyl tape in the end. I can push it in from the top without unbolting anything - it kept our caravan glued together and waterproof for 20 years Thumbs Up Tell someone you love them today because life is short.
Post #95227 20th Oct 2011 5:28pm
wurzell
hi Very Happy i had the plastic seals with the foam bits stuck on mine the plastic seals did nothing and the foam dropped off shortly after getting it ,ive just in the last couple of weeks fitted the 2011 door bottom seals absolutely brilliant no more drafts job done all in about £30 from LR Thumbs Up paul n tash
Post #95232 20th Oct 2011 6:01pm
ZeDefender
I've also got the new seals and they work well - I think the foam bits are rather obsolete now as the new door seals press against the frame and not on the side trim.
Post #95233 20th Oct 2011 6:07pm
df1
Just fitted the new seals to my TD5 last week.
Had to drill a few holes to fit the seals properly, also put some silicone on with the seals for extra peace of mind.
Fine job, should've been like this from new.
Post #95242 20th Oct 2011 6:50pm
ZeDefender
... like so many things... Tell someone you love them today because life is short.
Post #95278 20th Oct 2011 9:35pm
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
can someone post pix please Cool 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #95301 21st Oct 2011 6:53am
ZeDefender
If you mean the new-style door seals:
http://www.world-of-nanook.de/?page_id=117
They are held on by plastic stud-clips (about 5) in holes under the door.
Post #95307 21st Oct 2011 8:04am
