![]() | Home > Maintenance & Modifications > Foam seals |
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731
... the ones under the door frames.
Mine have fallen out after only 6 months and appear to do nothing except keep everything wet!!? Apart from the LR muppetry of using such things (looks better in the showroom?) should I replace them with: a) more pathetic foam tape b) butyl tape to seal the gap and keep water from entering from above c) nothing? Ta very much for input, Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Cheers I went for the butyl tape in the end. I can push it in from the top without unbolting anything - it kept our caravan glued together and waterproof for 20 years But shout it at them in German because life is also terrifying and confusing... |
| wurzell Member Since: 29 Jan 2011 Location: oxfordshire Posts: 141
hi
I've also got the new seals and they work well - I think the foam bits are rather obsolete now as the new door seals press against the frame and not on the side trim. But shout it at them in German because life is also terrifying and confusing... |
| df1 Member Since: 06 Aug 2011 Location: Ireland Posts: 221 |
Just fitted the new seals to my TD5 last week.
Had to drill a few holes to fit the seals properly, also put some silicone on with the seals for extra peace of mind. Fine job, should've been like this from new. |
... like so many things... Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
| chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 897
can someone post pix please
Beer 'n Sex 'n Chips 'n Gravy ![]() |
If you mean the new-style door seals: http://www.world-of-nanook.de/?page_id=117 They are held on by plastic stud-clips (about 5) in holes under the door. Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
