Home > Maintenance & Modifications > Foam seals |
... the ones under the door frames.
Mine have fallen out after only 6 months and appear to do nothing except keep everything wet!!? Apart from the LR muppetry of using such things (looks better in the showroom?) should I replace them with: a) more pathetic foam tape b) butyl tape to seal the gap and keep water from entering from above c) nothing? Ta very much for input, Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
20th Oct 2011 3:19pm |
Cheers I went for the butyl tape in the end. I can push it in from the top without unbolting anything - it kept our caravan glued together and waterproof for 20 years Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
20th Oct 2011 5:28pm |
wurzell Member Since: 29 Jan 2011 Location: oxfordshire Posts: 141 |
hi i had the plastic seals with the foam bits stuck on mine the plastic seals did nothing and the foam dropped off shortly after getting it ,ive just in the last couple of weeks fitted the 2011 door bottom seals absolutely brilliant no more drafts job done all in about £30 from LR paul n tash
20th Oct 2011 6:01pm |
I've also got the new seals and they work well - I think the foam bits are rather obsolete now as the new door seals press against the frame and not on the side trim. Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
20th Oct 2011 6:07pm |
df1 Member Since: 06 Aug 2011 Location: Ireland Posts: 221 |
Just fitted the new seals to my TD5 last week.
Had to drill a few holes to fit the seals properly, also put some silicone on with the seals for extra peace of mind. Fine job, should've been like this from new. |
20th Oct 2011 6:50pm |
... like so many things... Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
20th Oct 2011 9:35pm |
chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 893 |
can someone post pix please 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy |
21st Oct 2011 6:53am |
If you mean the new-style door seals: http://www.world-of-nanook.de/?page_id=117 They are held on by plastic stud-clips (about 5) in holes under the door. Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
21st Oct 2011 8:04am |
