![]() | Home > Maintenance & Modifications > My rusty hole and lower dash |
Plumbers91 Member Since: 30 Jul 2020 Location: Manchester Posts: 57 ![]() ![]() ![]() |
You’ll find quite a bit of the rust on the top of the footwells is from water running off the windscreen, down the channel and then dripping back down from the wing. You can use gum gum putty (I got some from Eastwood, look on frost.co.uk). And cover up the draining channel so it runs down the exterior of the car. Brittanica restorations covered a nice video on it. I’ll have a look for the link later if you want?
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1326 ![]() ![]() ![]() |
I mean you remove the inner and the outer together. Top of my head: - Remove fender flare. Just drill out the little cores and bull the little plastic clips and buy new clips to refit they are cheap - bolts connecting fender to bulkhead - these are actually pretty easy to remove - There is a little brace between the lower port of the outer fender and the bulkhead as well - bolts that hold the inner fender to the frame - Bolts that hold the outer fender to the frame and radiator bracket - Single plug that connects all the front end wiring I was breaking a car in my garden and I recall it was maybe an hours work to remove both sides. Not sure LHD and RHD if there is additional connections, maybe the bonnet release cable etc, but should all be plug and play. There is someone here repairing a DCPU and there is a picture where he has removed the same and you can see the great access that provides. Last edited by TexasRover on 22nd Mar 2023 11:53am. Edited 1 time in total |
Yes here we are: https://www.defender2.net/forum/topic86884.html Pictures show the amount of space you get. Also be helpful when refitting all the clutch/brake stuff back
