![]() | Home > Maintenance & Modifications > TC light only on - diagnosis help rqd |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2472 ![]() ![]() |
Can you swap the sensors over between the front wheels.i.e move the left to right and right to left. That way you can check if it’s a sensor issue as the fault will move to the other wheel if it’s the sensor.
Joncorry Member Since: 03 Apr 2022 Location: The Lake District Posts: 200 ![]() ![]() ![]() |
Good shout! Thanks Ian, I’ll give that a whirl. 2009 90 commercial.
2003 110 G4 used in 03 and 06 events - its well travelled. 2002 Range Rover G4 Event car (Australian leg) 2008 Discovery 3 G4 UK Selections car 1968 Series 2a |
Alternatively if you have a multimeter you can disconnect the sensor and measure its resistance the good one will give you the correct resistance value, then test the potential faulty one and compare.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915 ![]() ![]() ![]() |
If you have a scopemeter you can spin the wheel by hand and check the signal from the sensor for waveform and amplitude.
I don’t have a scope meter but I do have a multimeter. The drivers side (thought to be good) measure .859 k ohm and the passenger side .858 k ohm.
Not having a reference point to indicate if the numbers are good or bad, it only shows that both abs sensors are good or bad. 2009 90 commercial. 2003 110 G4 used in 03 and 06 events - its well travelled. 2002 Range Rover G4 Event car (Australian leg) 2008 Discovery 3 G4 UK Selections car 1968 Series 2a |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2274 ![]() ![]() ![]() |
The fault is showing it is the valve rather than the sensor, and the latter inputs to the ECU/Modulator which provides an output to the former.
Obviously it could be your ABS modulator, BUT I’d expect that fault to show the 3 amigos - TC, ABS and Brake warning lights. So fingers crossed it’s not that. It ‘could’ possibly be the shuttle valve - which you could replace with the ABS modulator in situ. I’ve been chasing faults around the ABS for some time ![]() Good luck and I hope it’s a quick/cheap fix 👍 |
Might be some help?
Apologies for the infantile scribbles… ![]() Click image to enlarge |
Thanks Screbble, I was just reading your thread earlier, hope it’s getting closing to resolution?
I’ve ordered a sensor as they are cheap enough to try and if not, I’ve got a spare for when one inevitably goes. I’ll have a look at the shuttle valve fix next. 2009 90 commercial. 2003 110 G4 used in 03 and 06 events - its well travelled. 2002 Range Rover G4 Event car (Australian leg) 2008 Discovery 3 G4 UK Selections car 1968 Series 2a |
hmm, sounds like I’m about 100k ohm under spec although mine is a TD5 and the thread is Puma, not sure if they changed at all?
I’m sure I got it all the way home when I refitted the passenger side but worth double checking just in case it is that simple! I’ll also find and pull the ABS fuse, see if I can get all three amigos to appear. 2009 90 commercial. 2003 110 G4 used in 03 and 06 events - its well travelled. 2002 Range Rover G4 Event car (Australian leg) 2008 Discovery 3 G4 UK Selections car 1968 Series 2a |
I’m getting closer… I replaced all four ABS sensors as they are relatively inexpensive and relatively easy to replace. I replaced the ABS shuttle valve in situ which was a pain in the proverbial. I then replaced the ABS modulator unit. I’ve manually bled the system and am at the ‘Nanocom’ stage I think. The 3 amigos have left the building. It looked like the brake fluid reservoir bushes/grommets had failed but I’m not so sure now. I hope to be back on the road soon. 👍 |
