Home > Maintenance & Modifications > TC light only on - diagnosis help rqd
Joncorry
 2003 Defender 110 Td5 G4 Challenge Tangiers Orange
Hello all, I’ve also posted this in my defender but as this is a specific issue, I thought I’d ask in this section if anyone has had and resolved the problem.
TC light has been on since I bought the Defner, doesn’t affect the way it drives but as its out of MOT, it will prevent me getting a new MOT.
Took the front left wheel off today to investigate the TC light issue. Removed the abs sensor, cleaned it up a little and then refitted. It was clean enough a quick wipe over was sufficient but no change to the TC light status. So, checked the wiring condition and the plug where it joins on the wing and again, all good.
Plugged in the new code reader (icarsoft 3) to read any values in the abs module and noticed the message about the LF Inlet valve being short to ground. It showed a value of 3.29V in the inlet only compared to the outlet and the RH inlet and outlet which all showed 0.07V. Unplugging the harness from the ABS block resulted in all values changing to 3.29V.
So, could anyone guess if it’s the sensor or valve block itself? Suggestions of things to check welcome!
 2009 90 commercial.
2003 110 G4 used in 03 and 06 events - its well travelled.
2002 Range Rover G4 Event car (Australian leg)
2008 Discovery 3 G4 UK Selections car
1968 Series 2a
Post #979079 21st Jan 2023 9:55am
Ianh
Can you swap the sensors over between the front wheels.i.e move the left to right and right to left. That way you can check if it’s a sensor issue as the fault will move to the other wheel if it’s the sensor.
Post #979117 21st Jan 2023 1:57pm
Joncorry
Good shout! Thanks Ian, I’ll give that a whirl. 2009 90 commercial.
1968 Series 2a
Post #979127 21st Jan 2023 4:51pm
Ianh
Alternatively if you have a multimeter you can disconnect the sensor and measure its resistance the good one will give you the correct resistance value, then test the potential faulty one and compare.
Post #979130 21st Jan 2023 5:02pm
If you have a scopemeter you can spin the wheel by hand and check the signal from the sensor for waveform and amplitude.
Post #979150 21st Jan 2023 7:13pm
Joncorry
I don’t have a scope meter but I do have a multimeter. The drivers side (thought to be good) measure .859 k ohm and the passenger side .858 k ohm.
Not having a reference point to indicate if the numbers are good or bad, it only shows that both abs sensors are good or bad. 2009 90 commercial.
1968 Series 2a
Post #979227 22nd Jan 2023 1:17pm
Screbble
The fault is showing it is the valve rather than the sensor, and the latter inputs to the ECU/Modulator which provides an output to the former.
Obviously it could be your ABS modulator, BUT I’d expect that fault to show the 3 amigos - TC, ABS and Brake warning lights. So fingers crossed it’s not that.
It ‘could’ possibly be the shuttle valve - which you could replace with the ABS modulator in situ.
I’ve been chasing faults around the ABS for some time Big Cry and others have said it’s important to verify whether it’s the sensors at this stage.
Good luck and I hope it’s a quick/cheap fix 👍
Post #979231 22nd Jan 2023 1:42pm
Screbble
Might be some help?
Apologies for the infantile scribbles…
Post #979232 22nd Jan 2023 1:52pm
Joncorry
Thanks Screbble, I was just reading your thread earlier, hope it’s getting closing to resolution?
I’ve ordered a sensor as they are cheap enough to try and if not, I’ve got a spare for when one inevitably goes. I’ll have a look at the shuttle valve fix next. 2009 90 commercial.
1968 Series 2a
Post #979237 22nd Jan 2023 5:05pm
Ianh
Post #979238 22nd Jan 2023 5:23pm
Joncorry
hmm, sounds like I’m about 100k ohm under spec although mine is a TD5 and the thread is Puma, not sure if they changed at all?
I’m sure I got it all the way home when I refitted the passenger side but worth double checking just in case it is that simple!
I’ll also find and pull the ABS fuse, see if I can get all three amigos to appear. 2009 90 commercial.
1968 Series 2a
Post #979243 22nd Jan 2023 6:17pm
Screbble
I’m getting closer…
I replaced all four ABS sensors as they are relatively inexpensive and relatively easy to replace.
I replaced the ABS shuttle valve in situ which was a pain in the proverbial.
I then replaced the ABS modulator unit.
I’ve manually bled the system and am at the ‘Nanocom’ stage I think.
The 3 amigos have left the building.
It looked like the brake fluid reservoir bushes/grommets had failed but I’m not so sure now.
I hope to be back on the road soon. 👍
Post #979260 22nd Jan 2023 8:50pm
