Home > Maintenance & Modifications > Swivel Kit for 2011 Puma
Page 2 of 2 <12
ChrisDefender
Many thanks all, you have all been extremelhy helpful and I now know what I need to source. I will update once it is sorted.
Thanks again, this forum is invaluable Thumbs Up
Post #978473 17th Jan 2023 10:40am
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
After much head scratching, can anyone confirm I'm looking at the right kit?
My chassis number is FA, so I need kit DA3180P?
Cheers 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #979381 23rd Jan 2023 4:06pm
Porny
Site Sponsor
DA3180P is the kit for ABS equipped late Defenders (inc Puma) - however, its not an OEM kit so wont have Timken Bearings and Corteco Seals. Its Britpart own brand kit, IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #979394 23rd Jan 2023 5:20pm
Rosco
Ian, thanks for the quick reply.
Any suggestion on which kit to get instead then? I do have ABS. Keen to avoid Britpart as much as possible given their lack of glowing reviews 2007 - Stornoway Grey 90 XS SW - Gone
Post #979395 23rd Jan 2023 5:22pm
Porny
Site Sponsor
I spend a lot of money with Britpart... but you have to just know what your buying. Some of their own brand stuff isn't actually bad.
Ian IRB
Post #979399 23rd Jan 2023 5:26pm
macfrank
An addition if it's just the seals. On our MY15, Land Rover fitted seals which don't have an outer dirt seal/lip >-( (the arrows point to the gap where there should be none and to the dirt that gets in there).
It seems there are different part numbers for the seal but they are not related to whether it's the proper one or the 'Excel-optimised' i.e. cheap one.
When I ordered LR059968/OEM I got a Corteco seal (12€). I also ordered another LR059968 and got allmakes (3€) - it has the old part number FTC3401 imprinted, but both have the outer seal and look very much the same.
Post #979462 23rd Jan 2023 9:22pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Hello chaps, looking to do this on my early td5 soon. I was wondering if any of you have changed the swivel seals using this method. Looks far easier than striping the hub. My swivel ball is in good order just the seal has become old and begun to weep. I can’t see any problem doing it this way.
Post #994530 30th May 2023 6:10pm
Dinnu
Nothing wrong with that approach if your swivel bearings, CVs and hub bearings do not need servicing.
Just be prepared that the swivel/hub assembly is very heavy.
When assembling back, ensure that the swivel does not rotate excessively in the other direction of the steering stop, as could damage the new seal. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #994537 30th May 2023 7:06pm
Kevlar
Czech Republic 2010 Defender 90 Puma 2.4 SW Santorini Black
I just fitted this kit to my 2010 DA3180G it was Britpart but with Timken bearings and Corteco seal.
https://www.island-4x4.co.uk/swivel-90110-...33080.html
Quality looks good, I fitted everything myself, first side took me a while but second side I got done in about 5 hours. Most of the time spent cleaning up the mess from the old leaking seals.
The guy at Island 4x4 is very helpful with selecting the correct parts for your Defender.
Kev
Post #994548 30th May 2023 8:27pm
landy andy
That’s always how I do mine. Even if fully rebuilding them. Remove as one big part, get it on a bench to work on. But if all else ok just new seal, refit, add one shot grease. A 14mm ratchet spanner makes it a quicker/nicer job.
Post #994557 30th May 2023 9:51pm
Page 2 of 2 <12
